Question about Pioneer Elite SC-25 7.1-CH A/V Receiver
Display POWER ON but SC25 not working.not reset
So I suggest you please help me with step by step instructions how to check and fix it.Let me re-state phenomenon: Plug the phone into the receiver, bright green light on Standby, press the Standby 10s, the lights go out. Then turn on the receiver using the remote or the Standby light and green light on reicever appear on LCD POWER ON and then no longer control.I do not have HDMI on both input and output signals. I look forward to his help. Thank you. vietson2457@yahoo.com.vn
    Problem Solver:
  • 5 Answers
My regservo need to active plz help me for activation code
Posted on Dec 29, 2013
  • SON TRAN VIET
    SON TRAN VIET Dec 29, 2013
    Thank Rezaxero I do not know how to find the code of SC25. I see the following barcode stamp machine: 0 12 562 95 745 6. CC 003 876 series production IHMP August 2009 in Malaysia. We look forward to his help.
  • SON TRAN VIET
    SERI IHMP 003876 CC .
2 Suggested Answers
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
Unit does not reset
Sounds like it it going in to protect mode. Very likely to have a bad output transistor(s). If discrete outputs are used in your receiver they are the larger components mounted to the heat sink. Sometimes only one transistor shorts other times many transistors, diodes, resistors and capacitors go bad. Take it to a service tech if you or no one that you know has some level of amp repair knowledge. Good luck!
Jul 04, 2013 | Pioneer VSX-1022-K Receiver
Loss of power and owners manual
Loss of power?? Need more info about fan. Make/model.Off the top of my head I would check out the capisator,which is the little black box with wires going to the pull chain switch. If it looks like it's expanding it is probably bad and needs to be replaced.
Feb 02, 2013 | Dryers
Hi there, I got a Canon Pixma MX320. One year ago, there got the error of "Document in ADF" and actually there was no any jammed paper. I sent it to Service Center and was fixed. But two month...
If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
    If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.
  3. Press the <ON/OFF> button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the <ON/OFF> button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
Solution:2 Load documents properly into the MX310 document feeder
Load the documents properly into the Automatic Document Feeder (ADF) Fan the documents and then align the edges before loading them into ADF.
  1. Remove all documents from the ADF.
  2. Fan out the sheets of paper well so that they do not stick together.
  3. Stack the documents on a flat surface to align the edges of the paper.
  4. Insert the top of the document, face up, into the ADF until a beep is heard.
Ensure that the edge of the document stack is in line with the Paper Size Mark (A) imprinted on the Document Tray.
Aug 30, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Need to reset sony ericsson xperia 10x cell phone
The Sony Ericsson Xperia X10 is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the Sony Ericsson Xperia X10 with step by step instructions.
Please note that all data will be deleted from the Sony Ericsson Xperia X10 as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
1. From the main home screen, tap menu
2. Tap Settings, then SD card & phone storage
3. Tap Factory data reset
4. Tap Reset phone
5. Enter your password, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
2. Hold the Left and right buttons located beneath the display
3. Press and release the Power button
4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Regards.
Aug 08, 2011 | Sony Ericsson Cell Phones
I have installed a new LCD screen on my acquasmart WL80T65CW1 and teh csreen now shows fault code 9. Please advise how to get rid of it and resize machine. Thanks.
Hi
If ever you replace the display PCB or the main controller PCB then you must set the size of the machine in to the memory of the controller. This should of been in the instruction sheet that came with the display.
This Is Fault Code 9 ,which indicates Size setting or
size error . When you changed the display did you size your machine to the new display module? Did you get the re-size set of instructions with the new display board? Ring up where you brought the display from and i"m sure they can help.
If this appears in your screen it will be necessary to set the size of the Aqua smart....
1. Press and hold the SPIN button, then press the POWER button until three beeps are heard.
2. Press the FABRIC SOFTENER button once to size the machine.
3. Press the POWER button.
If nothing works you need to reset your machine, please check the bellow link to get the manual and check page 18 and 23 for the reset instructions.
http://www.fisherpaykel.com//admin/pdfs/pdf_usecares/3731_LCDLED_Aquasmart_FINAL.pdf
Please get back to us if you have further query else please accept the suggestion.
Mar 20, 2011 | Washing Machines
My router did not come with any software do i need it because i cannot get mine to work
Please reset the router by placing a pin in reset hole and push the pin sslightly, (remember you need to do this when the rrouter is in ON state)
Then connect your router to your computer using ethernet port (this is for configuration) and also connect the ADSL cable.
now open internet explorer and type in //192.168.1.1
Then it will prompt you for username and password
Username: admin
Passsword: password
this username and password is by default.
then configure your router as you need by changing display name, password authentication, MAC registration etc...
If you face problem with connecting internet even following the above steps, then you need to contact ISP(internet service provider) for settings.
Thanks,
Satheesh
Jan 04, 2011 | ASUS RTN10 wireless router
My display screen is blank.why
Ifthe screen of the Camcorder is not working, please follow thetroubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to ON for more than 15 seconds,turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 04, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Display is gone wonky
First off, follow the instructions in this link to confirm that all the power and data cables are connected correctly. Then verify that the control panel overlay is firmly attached.(see link)
Then follow the steps in this article to reset the printer.
If your all in one has a photo memory card, also consult these instructions to reset the memory.
If none of these steps work to correct the display, please consult the troubleshooting section (pg 89) of the user's manual, available here, to see instructions for steps that will reset the language and measurement settings in the control panel display.
If that doesn't work, I'm afraid your unit will require service, or you could call or email HP to get technical support help from them.
Best of luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 23, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
Sharp xg-h400u projector Lamp timer reset.
plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
May 22, 2008 | Office Equipment & Supplies
Pioneer Elite SC-25 7.1-CH A/V Receiver Logo
148 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
