Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
New cartridges were put in printer but it will not print
New Cartridges were put in printer but neither will print
  • 56 Answers
Kodak discontinued the whole 5xxx series because of all the problems those printers had. Try calling Kodak's tech support to see if they can send you new print head or reimburse you for the printer.
Posted on Jun 01, 2009
jaylex
  • 417 Answers
SOURCE: alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
Posted on Dec 31, 2007
SOURCE: Printer doesn't print even with new ink cartridges.
Remember to remove the Seal Tape from the Top of the New Ink Cartridge as well as from the Bottom ! !
If a “Head Cleaning” cycle makes the Test Pattern worse, STOP.
Disconnect the Printer from the Computer.
Press the “Cartridge Change” button for ~ 3 Seconds.
When the Ink Cartridge Carriage travels to the Changing Position PULL THE POWER PLUG (NOT the “OFF” Switch). The Ink Cartridge Carriage should now Slide Freely on the Rail as long as it isn’t pushed to the Right so that it goes under the shelf to the “Homed and Locked” Position.
Fold up a Paper Towel (About 1 Sheet) so that its final width is about the same as the width of the gutter under the Print Head on the Carriage and so that it is thick enough when folded to contact and lightly press on the Print Head.
Saturate the folded Paper Towel with ~ 70% Isopropyl Alcohol and lay it in the Gutter.
Manually slide the Carriage and Print Head Over the wet Paper Towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is Correct.
Let the Print Heads rest on the Saturated Paper Towels for a few Minutes or Hours. Too long a Treatment may pull out all of the Cartridge’s Ink: Check the Paper Towel Frequently to Assess if Ink is Capillarying out onto the Towel.
When the Treatment appears Successful remove the Paper Towel and Clean Up and plug the Printer power back in.
Run a Test Pattern via the Computer Connection WITHOUT first running the Head Cleaning Utility.
If the pattern isn’t OK, Try Running the Head Cleaning Utility to see if it makes it Better or Worse.
If Worse, Repeat the Alcohol Paper Towel Treatment: The Paper Towel may be Gently Pulled back and forth under the Print Heads to wipe them off.
Posted on Mar 31, 2008
  • 28 Answers
SOURCE: Installed new OEM Epson ink cartridges, get error message 2. Cartridges are installed correctly and tested ok. Chip problem? Print head problem? Cartridge problem?
Go to printers and faxes, and uninstall the printer.
reboot, this should solve the problem
Posted on Apr 14, 2009
birky09
  • 104 Answers
SOURCE: i put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Posted on Nov 29, 2009
  • 159 Answers
SOURCE: Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Posted on Dec 29, 2009
My printer does not print after I just put new cartridges in printer.
You need to buy genuine cartridges. Take them back to the dealers and demand genuine cartridges that is if you did not force the cartridges into the slots. If you are printing blank sheets then change toner cartridges.
Oct 04, 2014 | HEWLETT-PACKARD Office Equipment &...
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Just put 2 new ink cartridges in my printer - black and tricolor. the printer receives the message to print, sends the paper through and sounds like it is printing, but then the paper is blank with no ink...
Hi
Just remove the new 2 cartridges and rub the print head in a plain paper with isopropyl alcohol until ink flows, and then return the ink cartridges and run the print nozzle for 2-3 times. After that, try to print again.
Please let me know if you need more help.
Mar 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
Printer will not print w/new cartridges
yes u put new and frsh .device mantanace also
Mar 11, 2010 | HP PSC 2410 All-In-One InkJet Printer
Just put all new cartridges in my printer and it will not print. paper goes through like it is trying to print. help please
have you remove sticker from cartridges first...if paper is feeding well then that new cartridges is empty or u haven't remove cartridge stickers from cartridges
Oct 26, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Check print cartridge light blinks
pull the cartridges, with the power turned off swab w/ alchol swab the communication ports that the cartridges fit into, let dry then reinsert the cartridges and turn on the printer. The com ports get infiltrated with ink wont read the new cartridges.
Oct 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer will not align
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Lexmark Z705 printer. I put in new ink cartridges
The BEST slution is GENUINE original cartridges. There is an eclectronic communicator on the cartridges and that "TELLS" the printer thet the current cartridges are not GENUINE ones. Untill you have replaced these cartridges with the GENUINE ones you will always get these error messages
Jul 08, 2009 | Office Equipment & Supplies
Froze on Aligning Print Cartridges...
hmmm..defective sensor???
try this..put the old print cartridges back in and see it does same thing..
check your computers warranty here FREE
Feb 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
131 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
