Question about Garden
I have a riding lawnmower yard machine 18.5 hp w/42 inch cut deck i am having a problem putting the deck back on there is a spring and hanging bracket that i cannot figure out where it goes. the only number found is 1183A MW there is a square between the A & M. any help would be appreciated. The front of the deck tilts downward without the spring and the bracket. The braqket has a bend from the factory. Please help my grass is out of control. Darryl
  • Dwain Pippen May 11, 2010
    What is your model # under the seat? I will try to figure out what you're referring to.
    Sniper:
  • 57 Answers
If this bracket is just like a heavy wire, it hangs from the right side of the transmission. It just hooks around the top of the housing and spring most likely goes from a bolt in the center of the metal plate at the back of the deck. If this doesn't describe your model, look under the seat for the model # and send a comment back. Lee
Posted on May 19, 2009
Where is bypass lever for craftsman lt1000 riding lawnmower
there is a rod hanging out from the rear of the machine you pull that out and move into the lock cut out
Jul 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I changed the blade mandrel from my 42 inch cut craftman mower, I need to put it back together I need a directions on how to put the spring and pulley back on also I damaged the nut on the pulley, What...
Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
GOOD LUCK
MIKE
Oct 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Cutting size question
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
450 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
