Question about Refrigerators
I have a GE Model GSL25JFTE BS side by side refrigerator. I left for 6 weeks and when I returned the water dispenser didn't work, but the ice maker seemed to work. Upon the advice from your website,
This problem showed up when I returned home after 6 weeks away.
SOURCE: Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Posted on Apr 04, 2007
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
SOURCE: I have a GE side
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Posted on Apr 19, 2009
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working but ice maker does
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Dec 03, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
