Question about HP Photosmart C6280 Printer
How do I incress the size of my photo
I am trying increase the size of a photo I am trying to copy. What should I do? What process should I take? What buttons do I press in what order?
    Problem Solver:
  • 10 Answers
Press "Copy Menu" The copy menu appears
press "down pointer" to highlight "Size" then press "OK"
The Size menu appears
press "down pointer" to highlight "Custom 100%" then press "OK"
The Custom 100% menu appears
Press "down pointer" or "up pointer" to select a percentage to reduce or enlarge the copy.
Press "OK" when happy with percentage to enlarge
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf page 91 and 92
Posted on Dec 29, 2013
4 Suggested Answers
  • 35 Answers
SOURCE: Cannot copy
Remove the colour cartridge and then see : "E" is displaying in its display board. If "E" appear then put it back in carriage and remove black cartridge. If "E" doesn't appear it means your black cartridge is not working properly. and vice versa with colour cartridge. This problem is belongs to cartridge. Try to change them. Problem will automatically solve
Posted on Sep 19, 2007
PABLOCSA
  • 1124 Answers
SOURCE: cannot cancel copy process
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Posted on Nov 18, 2008
Dicedonions
  • 118 Answers
SOURCE: Power button flashes and display says shutting down
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck .
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for trouble shooting problems
hope this helps and good luck
Posted on Apr 29, 2010
Is there a way to increase size of print off of what I am copying ?
Are you coping from your computer or just coping from the printer itself?
Mar 24, 2015 | Canon PIXMA MG3520 Inkjet Multifunction...
Hi there, How do I print my image on A4 without any margine. Thanks
Hi
u don;t want to use adobe phot shop, just copy your jpag file and open word and paste there and drag your photo and increases your photo size. this is tempo-rely option, Best u Install the Abobe Photo Shop.
Good Luck
May 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
I take photos but display in the computer photo size is post card size, how to make little big picture
The size of a picture/photo depends on the resolution that you have set on the photo capturing source(webcam, Digicam etc). So you need to increase the resolution as much as possible to increase the size and quality on the photo. It will also increase the space required to store it.
Hope this will help.....cheers:)
Jan 02, 2011 | Computers & Internet
How do I increase the size of copy on an Epson Stylus Photo TX650
Hi
Check Print settings on Menu to adjust sizes and preferences.
Hope this helps.
Dec 17, 2010 | Epson Office Equipment & Supplies
How do I copy and enlarge a 4" x 6" photo to 8.5" x 11" sheet of paper?
You need a scanner and an imaging software (i.e. photoshop).
- Scan the original photo
- increase the resolution on the software to at least 300dpi
- increase/modify the size of the image to 8.5 x 11
- save new image under a different name
Different software have different detailed instructions, but the general objective is as described above.
Hope it helps
Nov 06, 2010 | Computers & Internet
How do I set photosmart B209 to enlarge copies?
http://h10032.www1.hp.com/ctg/Manual/c01796502.pdf
Pg 57 Item c, where is says touch size, instead of fit to page, you should have other options to increase or decrease the size.
Another option it to scan the item to the computer then print and enlarge during the print process
Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Problem saving scanned negatives to laptop. Epson 2400 scanner.
If you are scanning in Color and in high resolution, then the file size will be very big. Try and close other programmes in your Laptop and try. If in color try 150 or 200 dpi option and also select JPG format. Alternatively you can increase your RAM in the laptop. S. Mohan
Nov 13, 2008 | Epson Perfection 2400 Photo Flatbed...
Panasonic DMC-TZ3 72 dpi problem
Sounds like Photoshop's setting, or default setting, is to import picture at its maximum size. If you RESIZE pic on Photoshop, it shoud automatically increase DPI while reducing physical size.
The other thing to be aware, TZ3 defaults to a certain jpg compression. You can minimize compression of data with settings options on TZ3, but I doubt this has anything to do with your PhotoShop issue.
Also, in SIMPLE mode you can select a physical size for photo, even after pic is taken(resize), on camera.
Hopes this helps.
May 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Photo size too large for email
You can do that in 2 ways.
1) Shoot the photo or video in reduced size (less quality). This can achieved by adjusting the settings in your camera.
2) Use 3rd party software like photoshop or Microsoft paint to manually reduce the size using it.
Jan 20, 2008 | Kodak EasyShare Z700 Digital Camera
HP Photosmart C6280 Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
