Question about Siemens (120-5830-001) Modem
How to forward ports on Siemens Gigaset 204 A modem
Evey time i click on active and hit save it says (The subnet mask does not match the ip address
  • 1 more comment
  • topstunner May 22, 2009
    ADSL Modem... but I click start then CMD then type ipconfig it says ipv4 192.168.254.3 mask is 255.255.255.0 and the default gateway 192.168.254.254
    I use the "gateway" to get on the Modem.
    It is Something called GGPO that im trying to forward ports for. ggpo.net
    never mind i got it
  • George Day May 11, 2010
    Is it a modem or a router? What ip address and mask does it show?
5 Suggested Answers
SOURCE: connecting to xbox live with a speedstream 4100
force the gateway on the xbox configuration... retrieve gate from command prompt of your pc depending on the os.
Posted on May 18, 2008
SOURCE: connecting to xbox live with speedstream 4100
TUrn on the computer with the speedstream 4100 connection, like you always would, then when on and fully booted, unplug ethernet from modem, plug in ethernet cord from xbox. Turn on X-box, then restore factory settings. Should work
Posted on Dec 04, 2008
OldEangle
  • 8 Answers
SOURCE: Reseting the admin password on siemen gigaset modem
Usually at the back of the modem has an inside button (it has the tag "reset") that u can push it with the help of a object that has a point. (e.g pencil).
Posted on May 04, 2009
WiFiNut
  • 53 Answers
SOURCE: Ip address to access Siemens sb5830
Make sure you are on the same subnst as your router.
Go to:
http://192.168.254.254
login is superuser
password is admin.
Posted on Jul 06, 2009
Connect fuji xerox printer - mac pro computer as it was
Hi Lindsay. Was the fuji xerox printer plugged into the old modem by a blue ethernet cable ?
When you changed your modem it would have had a device inside it called a dhcp server that allocated the IP addresses to your computers automatically.
Now I suspect that the new modem has a device inside it called a DHCP server that is allocating a different range of IP addresses to your computers from waht it used to be.
Here comes the technical part
On the printer menu screen there should be a network setting option . Take a note of the IP address of the printer it will be 192.168.0.x or 10.0.0.x x being the unknown number. also take a note of the subnet mask . it will most likely be 255.255.255.0
next but I have no idea how to look that up on a MAC IOS system.
you may see the ip address in the printer settings properties in the MAC
you may be able to get your ISP to remotely set up your DHCP server in your router to work in the appropriate ip range to match your printer IP address and to avoid allocating the printers ip address to your computers. Then restart the computers to get new ip addresses.
If you tell them the printers IP address and Subnet mask they should be able to alter the modem's settings DHCP settings for you.
The other option is to get the DCHP IP address range of the modem and subnet mask and change the printers IP address setting and subnet mask to match the DHCP leases range by giving it a much higher number than the computers are most likely to be running on.
so if the range was 10.0.0.1 to 10.0.0.254 with subnet mask of 255.255.255.0 then the printer would be set to 10.0.0.254 and subnet mask 255.255.255.0 The first three left numbers must match they are known as the network component of the ip address 10.0.0.0 or it may be 192.168.0.0 the zero end number is the network address so you can't allocate it to a device. 192.168.0.1 or 10.0.0.1 is usually the modem address.
ISP may be able to guide you how to change the setting on the printer .
I had a client that had a lot of trouble getting a tech to come out and set up their printer to an APPLE system. I was the final Tech that eventually came out and set up the printer .
Feb 17, 2016 | Computers & Internet
Tip
Change ip address
How To Change Your IP Address
How do I change my IP? There are MANY methods to change your IP. Some methods will work for you but may not work for someone else and vice versa.
If your IP is static, then you CAN’T change it without contacting your ISP.
If you have a long lease time (explained in this article) on your IP then you won’t be able to change your IP without cloning your MAC address, which I’ll explain later in this article.
It definitely helps if you know how the IP is being assigned to you.
You can read our DHCP definition to get a better understanding.
What is an IP lease time? IP lease time is the amount of time your ISP determines you’ll be assigned a particular IP. Some IP lease times are just a few days and other IP lease times could be set for a year or more. This setting is completely up to your ISP.
One of the easier methods to change your IP is to turn off your modem/router/computer overnight. Then turn it back on the following morning. This method WILL NOT work if your ISP has a long lease time set for your IP.
The following method will ONLY work if your computer is being assigned your external IP and not a router.
How to determine if your computer is being assigned the external IP
If your connection is direct to your computer and your computer gets the public IP and not a router, you can try this:
For Windows 2000, XP, and 2003
1. Click Start
2. Click Run
3. Type in cmd and hit ok (this opens a Command Prompt)
4. Type ipconfig /release and hit enter
5. Click Start, Control Panel, and open Network Connections
6. Find and Right click on the active Local Area Connection and choose Properties
7. Double-click on the Internet Protocol (TCP/IP)
8. Click on Use the following IP address
9. Enter a false IP like 123.123.123.123
10. Press Tab and the Subnet Mask section will populate with default numbers
11. Hit OK twice
12. Right click the active Local Area Connection again and choose Properties
13. Double-click on the Internet Protocol (TCP/IP)
14. Choose Obtain an IP address automatically
15. Hit OK twice
16. Go to What Is My IP to see if you have a new IP address
For Vista
1. Click Start
2. Click All Programs expand the Accessories menu
3. In the Accessories menu, Right Click Command Prompt and choose Run as administrator
5. Click Start, Control Panel, and open Network and Sharing Center. Depending on your view, you may have to click Network and Internet before you see the Network and Sharing Center icon
6. From the Tasks menu on the left, choose Manage Network Connections
7. Find and Right click on the active Local Area Connection and choose Properties (If you’re hit with a UAC prompt, choose Continue)
8. Double-click on Internet Protocol Version 4 (TCP/IPv4)
9. Click on Use the following IP address
10. Enter a false IP like 123.123.123.123
11. Press Tab and the Subnet Mask section will populate with default numbers
12. Hit OK twice
13. Right click the active Local Area Connection again and choose Properties
14. Double-click on Internet Protocol Version 4 (TCP/IPv4)
15. Choose Obtain an IP address automatically
16. Hit OK twice
17. Go to What Is My IP to see if you have a new IP address
Some people have inquired about manually assigning their IP address. This IS possible, but you run a very high risk of your ISP banning you from connecting to the internet. To manually change your IP, follow the steps above for your Operating System. In step 9 or 10, depending on your O/S, enter an IP similar to the one displayed in the command prompt window. For example, if the IP displayed in the command prompt window is 75.1.2.3, change yours to 75.1.2.4. You’ll also need to manually enter the Subnet, Gateway and DNS Server IP addresses as well. If the new IP you give your computer doesn’t work, chances are someone else on the ISP network has already been assigned that IP. You’ll need to move on to the next one and keep trying until you find an open one. However, some ISPs match up your MAC or modem data to the IP that’s been assigned. If those 2 things don’t match up, you won’t be able to connect no matter what. If your router gets the IP and not your computer, you’ll need to http in to your routers interface and manually assign the IP there. It’s pretty much the same method as assigning the IP to your computer. The method that varies is in how you reach your routers interface. You can get the instructions from your manufacturer’s website.
on Jul 02, 2010 | Computers & Internet
How do I change my mtu settings on a Dynalink rta1025wv6
OK, a little summary of what is going on with your modem. I have the same model and I know exactly what is happening. Here is the reason: (the solution is at the bottom of this article but read this so you know what, and what not to do, sweet?
In this model, there is a setting called; DMZ host which is found in virtual servers. This is the reason why you are not getting an open NAT because the XBOX is being blocked by the security of this function called DMZ. DMZ is a virtual host that will tell the modem security to let in the outside world without any security breaches. You can research more on this yourself so here is the solution.
(IMPORTANT NOTE) I highly recommend resetting all your modem settings so you do not run into any other problems as I did. I have tried this 10 times and it works every time. Once you have rest your modem settings. every setting is already to go but just needs you to activate it, cool?
1. open up your modem settings (192.168.1.1)2. go to advanced tab and click on local network and then UPNP. (make sure this is enabled)3. Save & apply.4. Now go to virtual servers and click on port forwarding.5. In the custom service box type in a name that will remind you that its for XBOX, i used XBOX 360.6. Enter all these ports *** follows:
Port start 3074 port end 3074 and TCP protocolPort start 27014 port end 27050 and TCP protocolPort start 3074 port end 3074 and UDP protocolPort start 3478 port end 4380 and UDP protocolPort start 27000 port end 27030 and UDP protocol
7. go in DMZ host and type your ip address which should be 192.168.1.1 (the main ip address) and then save and apply.
8. reboot modem.
Go in XBOX network settings and in basic settings manually type 192.168.1.200 in ip address, 255.255.255.0 in subnet mask and 192.168.1.1 in gateway.
9. DNS settings should be automatic.
10. reboot XBOX you are ready to go.
TEEMAN
Oct 12, 2011 | Computers & Internet
How can I access speedstreem siemens4200 settings?
default configuration settings page is 192.168.0.1. Make sure that the IP address of your machine is on the same subnet as the IP of the modem (192.168.0.x, Subnet Mask of 255.255.255.0).
Let me know if you have any other questions.
Jan 10, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Can not get my xbox to connect to my netgear 614v7 router am using a lan connection but it cant get a IP address from the router any ideas ??
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address 192.168.1.50.
Click On 'Apply'.
10. Log Out of the Router Page.
Please repeat Steps 3 – 7 to configure the ports “UDP/TCP 3074”.
Jan 03, 2010 | NetGear WGR614 Wireless Router
Connecting NETGEAR Wireless RouterWPN824 v2 to PC HP2009m tru Comcast Airrs Modem for use by Xbox360 in another room
the Router.
Address as: 4.2.2.2
port as 88.
7. Hit ‘Apply’.
Click On 'Apply'.
Dec 30, 2009 | NetGear RangeMax WPN824 Wireless Router...
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
I have netgear wirless router but i hardline ps3 but i keep getting nat type 3 i need to know what ports to open on modem to get to nat type 2 can you help
the Router.
Port numbers:TCP: 80, 443, 5223 and UDP: 3478, 3479.It is in this context, I would suggest you to please try with the
Address as: 4.2.2.2
4. Give a name to the service (for example, PS1).
port as 88.
7. Hit ‘Apply’.
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
Port forwarding
What is the manufacturer of your router so I can get a user guide and taylor the instructions if needed?
Generally I would statically address the device to be forwarded to. If your router address is 192.168.1.1 and Subnet mask of 255.255.255.0 and it's DHCP server controls address 192.168.1.100 for 50 leases to 192.168.1.149 then consider using the range 192.168.1.2 - 192.168.1.99 uniquely as static IP addresses. There are more starting at 192.169.1.150 but let's ignore them for now. In the network adapter to recieve port forwarded content assign a static IP address based on the above as say 192.168.1.15 with a subnet mask of 255.255.255.0 and a default gateway of 192.168.1.1. The DNS addresses should also be static however depending on your router there may be an option. Some routers allow their address to be entered as the DNS address and pass requests as appropriate to the DNS servers loaded in their lan configurations, otherwise you will enter your ISP supplied DNS addresses into the network configuration.
Now that we have established a stable IP address to forward the port to we need to tell the router everything it sees for port 5060 gets forwarded to IP Address 192.168.1.15 port 8000. If detailed instructions are needed I will need to know the manufacturer and model of your router.
Please provide the additional information and any questions in a response to this problem and I will respond when available.
Dec 25, 2007 | Computers & Internet
Siemens (120-5830-001) Modem Logo
1,067 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
