Question about GE 25952EE1 Cordless Phone
Display is not working properly - GE 25952EE1 Cordless Phone
How to replace display of ir2800
  1. Open the Right door.
  2. Open the two screws Marked as 1and 4.
  3. Open Last One screw Left side a hole in Display.
  4. Remove the connector with safety.
  5. Open the 4 Screws back side of the display.
  6. Disconnect all the Connectors.
  7. Remove all the Circuits.
  8. Remove all the Self threaded Screws.
  9. And Remove the Iron Base Plate.
  10. And Safely replace the Display with new one.
  11. Place the Touch Screen Properly.
  12. And reinstall The Iron Base Plate.
  13. Place all the Circuits.
  14. Connect all the Connectors as connect they before disassemble.
  15. Reinstall Properly the Display as Before It Place.
  16. Now on the machine and check it...boom boom..
Do not Do That:
  1. Do not use Thinner and Hard stain remover Acids.
  2. Do not clean the circuits with liquids.
  3. Connect all the Connectors at Proper port.
  4. Place the screw well fit to display and touch screen to work touch screen properly.
  5. Do not give room with Display and Touch it may not work properly.
May 14, 2016 | Canon Ir 3300 Black & White Copier
LED not working properly
Yes, I have exactly the same problem after running the de-scale routine, we've only been using the machine for 4 months (in Melbourne where the water is soft). You can dimly make out the icons on the display and the machine works Ok. The display contrast is set correctly, yet the green images are not showing up properly while the red images do show up.
Sep 07, 2014 | Saeco Intelia HD8752
My fairly new Cannon SX230's LCD display stopped working properly.
Hi! Try this. Press and hold the disp button down for 2 to 3 seconds. The display should brighten up for you.
Feb 05, 2012 | Canon Sx230 IS Digital Camera
Display problems
First try to find the proper driver from it's MFGs' site. If not work, try install your MS Windows from scratch. If default driver works well just keep it otherwise, install your display card driver.
BR,
Wahid
Aug 19, 2009 | Gigabyte GA-8LD533 Motherboard
Samsung mobile sgh-i640v not working properly display after any call call failed and push camera key display message unable to connect camera
my mobile sgh-i640v desactive hemself evry time whats is the problimeeeeeeeeeeeeeee pleaseeeeeeeeeeeeee help meeee
May 11, 2009 | Cell Phones
Main Display
Hi. Have you tried replacing the LCD screen? You can buy one herehttp://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see thedisassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nov 14, 2008 | Nokia 6131 Cellular Phone
My ati graphics card is not working
do you see the display. what kind of card problem you have.
check is it properly pluged in the slot. b'coz graphic card not working have few possibilities.
if no display then try to plug it properly in slot.
if display but graphic not proper then driver problem. install its driver again after uninstalling.
regards,
Jul 23, 2008 | Gateway Computers & Internet
Display
I have Intel Jetway 945 Mother Board, I checked the Processer and Ram, And SMPS it is working properly, but I am facing display problem.
Oct 29, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
GE 25952EE1 Cordless Phone Logo
32 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
