Question about Home
Are uberhaus shower diverters reversible
Hot and cold are reversed on my shower diverter can you pull the cartridge and switch the hot and cold
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • 35 Answers
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Posted on Nov 18, 2009
  • 10865 Answers
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Posted on Mar 18, 2010
  • 349 Answers
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
Posted on May 16, 2010
SOURCE: Have Moen tub facet with a single handle and
I have already replaced my MOen cartridge on brand new faucet and still drips. Just like yours does.
Posted on Aug 11, 2010
My shower won't switch on at all and the flow dial makes a humming sound when turned . any advice please .
check your tub diverter (spout that fills tje tub). then check the cartridge in the water (hot n cold) faucet.
Jun 03, 2016 | Home
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
How to adjust hot water on shower
Turn on the hot water first. Wait for it to warm up, then turn on the cold water until the mix is the temperature you want. I recommend doing it before you engage the shower diverter to divert the water to come out the shower head.
Sep 19, 2014 | Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
1 HANDLE TUB/SHOWER. WHEN YOU TURN THE SHOWER ON
The diverter is worn and needs to be replaced.
The diverter is the lever/button you pull/push to switch from shower to tub. When they get worn, they require more pressure to seal properly and divert the flow.
Aug 06, 2009 | Delta T13420 Chrome Classic Single Handle...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
