Question about Cyber Acoustics CA-3908 3 Piece Flat Panel Design Subwoofer and Satell
Can't connect CA speakers to my Xbox - Cyber Acoustics CA-3908 3 Piece Flat Panel Design Subwoofer and Satell
Xbox360 to pc monitor
HDMI to DVI works better than HDMI to VGA because VGA only uses simple RBG scheme.
Additionally the only way i see the Xbox getting connected to the extrenal speakers is if you get the speakers connected to the monitor/tv or whatever you are using directly. I havent tried or do not know of any way to connect the Xbox to speakers directly.
Dec 17, 2013 | Microsoft Xbox 360 Console
Older XBox 360 with wireless antenna - can't connect to network - why not?
What color does your wireless adapter (xbox) turn when you power on your xbox? Green, Red, or Grey (No light)?
If it's grey(no light), try connecting the adapter into one of the USB ports in front of the console(the usb ports are behind that flap)
If it's red, it's a hardware problem and you should try and repair it.. or replace it (xbox antenna).
If it's green, then it's something to do with your network settings.
Good Luck
Jan 12, 2013 | Video Game Consoles & Games
No sound on kinect chat
  • Make sure that the Xbox 360 A/V cable is properly connected to your audio system.
  • Make sure that all speakers are connected to your audio system.
  • If your audio system has speaker switches, make sure that the switches are on.
  • If your audio system has a receiver mode, make sure that the setting matches the number of speakers connected. For example, If you have Use this mode Two speakers Stereo Five speakers and a subwoofer 5:1 Seven speakers and a subwoofer 7:1
  • Make sure the settings on your xbox are configured correctly so as to allow kinect chat
  • Jan 13, 2011 | Computers & Internet
    Connecting computer speaker to a receiver
    Which output section of the Denon are you using? Tape monitor out? And are you getting sound through the speakers (not the PC speakers) that are attached to the Denon speaker terminals?
    Oct 26, 2009 | Denon AVR-1601 Receiver
    Only got sound threw 1 speaker, everything is connected correctly.
    were did u get the drivers from my mate as i am in the same sh..
    May 27, 2009 | Cyber Acoustics CA-5150 Computer Speakers
    Yamaha HTR-6130 sound only from centre, rear or front speakers
    its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
    May 18, 2009 | Yamaha HTR-6130 Receiver
    Spherex Xbox 5.1 Surround suound..USB does not work
    If the xbox is not able to recognise the usb, it is most likely that the product is not compatible with the xbox i would look for an adapter which would take the usb connection to the xbox's analog connection, or if your speakers have a stero 2.5 connection then you can easily find an adapter to connect to the xbox's analog connection in the back, the analog connection is the red and white ports at the back!.
    Feb 11, 2009 | Spherex Xbox 5.1 Surround Sound System...
    Re:ca-3000 speakers
    see there is power on speaker and check the audio cabe connection is it properly connceted to audio jack in your sound card. bye
    Aug 09, 2007 | Cyber Acoustics CA-3000 Computer Speakers
    Cyber Acoustics CA-3908 3 Piece Flat Panel Design Subwoofer and Satell Logo
    14 people viewed this question
    Top Cyber Acoustics Audio Players & Recorders Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Carlos L. Burgos
    Carlos L. Burgos
    Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
