Question about GE DPSR483EA Electric Dryer
Dpsr475ewoww dryer electric ge belt
How to replace the belt
5 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Posted on Sep 26, 2009
heatman101
  • 43501 Answers
SOURCE: Electric dryer - Replace timer ? GE DDE7206MCLWH
Here is the best way I have found to get replacement parts.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 16, 2009
SOURCE: How to replace belt on Ge dryer # DNXR473GW0WW
dryer was working ,when wife checked on it , the dryer had stopped with 20 min. left. now it's as though there is no power to the mach. I have checked and there is power at the location.
Posted on Apr 17, 2010
heatman101
  • 43501 Answers
SOURCE: GE DPSR483EA Electric Dryer was making a scraping
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
GE dryer turns on but doesn't spin
Probably nothing but a broken belt. Ge dryers can be tricky. Most of them cannot be accessed from the rear anymore. Lots of videos on youtube now that show how to replace a dryer belt on a GE dryer.
Mar 20, 2014 | General Electric GE 7 0 Cu Ft Super...
Squeling on dryer model #dpsr475ewoww
replace the belt and tensioner pully to eliminate the squealing
Sears sell these parts in sets
Jun 07, 2010 | GE DPSR483EA Electric Dryer
Won't start all of a sudden. Power is getting to the unit, no breakers thrown. Interior light works... just won't run. What do I check first? GE model DPSR475EWOWW
First, find your breaker box and locate the breaker that runs the dryer. Now flip the breaker off and then back on. Now try the dryer. If it made not change. Gain access to the back of dryer. There is a small panel toward the bottom that you can take off. After unplugging the dryer, take the little panel off. Look inside and check the belt. Make sure it is tight and still going around the motor shaft and pulley. With this model, there is a switch that turns the dryer off so that it will not run when the belt comes off. If the belt is on, you will have a bad thermal fuse and bad cycling thermostat. The thermal fuse is located on the top of the element housing and the cycling thermostat is located on the blower housing. When the cycling thermostat goes out the dryer then cycles on the thermal fuse until it goes bad. This then cuts the power on one leg of the 220V coming to the dryer. Remember, a dryer runs off of 220vs. This consist of two 110v legs. The element is the only component inside the dryer that works off of both 110v legs. Some component work off of one leg and the other component work off the other. When you loose one leg, some things will work and others will not. I hope this makes since. It's the best way I can explain it. If I can explain any of this or help anymore, please send a comment back to me.
Please rate solution and good luck.
Sep 07, 2009 | GE Profile DPSR475EW Dryer
Dryer belt replacement
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Belt Not Tight
The belt gets tight when you press the pulley arm down place the belt over the outer edge of the pulley and then over the motor axis. The belt then runs like in a "eight". Christian
Jun 26, 2007 | GE DPSR483EA Electric Dryer
GE PRofile DPSR475EWOWW
Don, the drum on this model rotates on a bearing in back. This is most likely where the sqeeling is comming from. You will have to service this from the front. Should be 2 screws just above the door on each side. Remove them and the top will lift up. Slide the top off forward. Once the top is off, you will see a couple of screws holding the the front panel and door assy. on. One on each side inside front panel. Unplug the door harness and remove the front panel and door. Undo the belt and the drum should pull straight out. Watch out not to get the belt hung on the motor. Now you will see the rear bearing and shaft bracket that the drum rides on. It may need to be replaced or just lubed up real good. Catriver.
Jun 22, 2007 | GE DPSR483EA Electric Dryer
GE DPSR483EA Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
