Question about Dell Latitude D600 Notebook
User profile service will not load. Enter password will not let me even in desktop to do anything
  • 300 Answers
SOURCE: Dell Inspiron 1420 - says user profile cannot be loaded
Try this, it should work and it really is quite easy to follow -
1. Boot up in Safe Mode. To do this, hit the F8 key while the computer is
booting, and then scroll down to the "Safe Mode" option and press enter. On
my computer the user account icon appeared, but bigger than normal, and I
clicked it and it loaded my desktop in safe mode. It came up with an error
bubble saying that my user account hadn't loaded properly, but I just ignored
this.
2. Click the Start Button and in the white "Start Search" space at the
bottom type "regedit" (without the quotation marks). This will open the
registry editor.
3. In the left-hand pane, navigate by clicking the little triangles next to
the following folders:
HKEY_LOCAL_MACHINE
SOFTWARE
Microsoft
Windows NT
CurrentVersion
ProfileList
You should now have a list of folders all starting with S-1-5- and then a
number.
(You might need to drag the divider between the 2 panes of the window across
so you can read the whole folder name)
Look at the end of each name and you should see one with .bak at the end of
it, and there will be another one above it with exactly the same name but
without .bak at the end.
The one that's got .bak at the end is your old User Profile that Vista has
now made into a backup, and the one without .bak after it is the new empty
User Profile that Vista has created.
Just to check that this is the case, have a look in the right-hand pane for
each of the 2 folders and look at what's written after "ProfileImagePath".
For the folder with .bak at the end it should say C:\Users\ and then your
usual User Account name, and for the one that doesn't have .bak at the end it
should say C:\Users\TEMP.
What you need to do now is to rename the folders in the left-hand pane so
that the one with .bak at the end changes back to being the one containing
your proper User Profile and the new one without .bak at the end becomes the
backup. Do do this follow the next step:
4. Right click on the folder with .bak at the end and then click "rename",
and just change the ".bak" part to ".bk" - i.e. just remove the "a" from the
middle - (this is just to allow you to change the other one to have .bak at
the end). Press enter or click on some blank part of the screen for the
change to take effect.
Then, right click the one that doesn't have .bak at the end and click
"rename". Remove the .bak from the end and press enter or click anywhere on
some blank part of the screen to accept the change.
Then, right click on the one that now has .bk at the end, choose "rename"
and add the "a" back into the middle, so it now has .bak at the end. Press
enter or click on blank park of screen to accept the change.
Close the regedit window.
5. Click the Start Button and then "Restart".
It should work now, otherwise see link below -
http://support.microsoft.com/kb/947242
Posted on May 21, 2008
PauldLucky
  • 268 Answers
SOURCE: User profile cannot be loaded
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
Logon to the Computer
NOTE : Go down the list here until you find a option that will work for you.
1. Logon to another Administrator account.
NOTE: If you do not have another Administrator account, then proceed to step 2.
A) Go to OPTION ONE or OPTION TWO.
2. Boot into Safe Mode.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
C) Go to OPTION ONE or OPTION TWO.
OPTION ONE:
Fix the User Account Profile
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
OPTION TWO:
Delete the User Account Profle
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
1. Delete the User account profile that this error is for.
NOTE: See: How to Delete a User Account in Vista
2. Open the Start menu.
3. In the white line (Start Search) area, type regedit and press Enter.
4. If prompted, click on Continue.
5. In regedit, go to: (See screenshot below step 7)
6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it.
NOTE: It may have .bak at the end of it.
A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.
B) Repeat step 6 until you find the one that you deleted in step 1 above.
NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.
7. To Backup the Registry SID Key -
WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.
A) Right click on the SID key, and click Export.
B) Type in a name and save the REG file to a safe location.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
C) Continue on to step 8.
8. To Delete the Registry SID Key -
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
10. Now, just create a new normal Administrator account.
NOTE: See: How to Create a New User Account in Vista
11. Restart the computer, and logon to your new account.
Good Luck.
Live, Love, Laugh.
Posted on Sep 11, 2008
SOURCE: dell inspiron 1525 notebook
Posted on Oct 06, 2008
  • 51 Answers
SOURCE: Dell Studio Laptop- Cannot Log On Message- User
I had one case like this before where there was another user on the machine who loaded the user profile hive in the registry and then forgot to unload it. Therefore when the user tried to log in, it gave them the message just like yours because it's "in use" by the registry. If there is another user on your machine, please ensure that this person unloaded the hive in the registry. And then try logging in again. Please let me know if the problem persists. If my suggestion works, please do rate me. Thanks.
Posted on Feb 04, 2010
  • 41 Answers
SOURCE: On booting up my Inspiron
Try logging in on the admin acct then delete and recreate the profile. If it doesn't work you can try switching off the comp then continously press F8 while turning on the comp and choose safe mode, then do a system restore.
Posted on Mar 18, 2011
Wont let me logon out of the blue
You can reset your windows password with PC Login Now
PC Login Now v2.0
. Take note thet it is not a free application but a shareware.
Review PC Login Now The Fastest Password Cracker Ever
You also can test 7 Free Windows Password Recovery Tools
May 14, 2015 | Dell Dimension Computers & Internet
I hv HP 6930p elite notebook.wen i switch on nd
The hard way mayB you have been hacked, take the harddive out get another computer and check the harddrive for virus.
Oct 16, 2014 | Computers & Internet
When I turn on laptop I get an error message that says "The User Profile Service service failed the logon. User profile cannot be loaded what do i do i cant not get on that laptop at all and i do my...
either you are entering the wrong user name and password or the someone with admin rights deleted your user profile from the laptop. another possibility is that your operating system is corrupted. have you tried to enter your laptop in safe mode? if not then you should try to enter in safe to see if your user profile is good.
Sep 04, 2011 | Computers & Internet
I try to login and enter my correct password and it tells me user profile service service failed the logon. User profile cannot be loaded....
Could be the User Account is damaged. Can u click F8 on startup and sign on as administrator? If so, go into control panel and into users and create a new user then restart the computer and sign into this new account.
Then you should be able to go into you C drive and retrieve the documents from the damaged user account.
Let me know if I can be of any more help.
Jan 22, 2010 | eMachines W3653 Refurbished Desktop...
When i turn my computer on it will not allow me to login in. Once I enter my password it tell me that ''the user profile service service failed the logon, user profile cannot be loaded".
reinstall windows.  it may be a virus disabled and destroyed the profile service, so even if you were to boot into safe mode and attempt to access windows services and turn it on and start it automatically, when you rebooted to normal operation, it would still tell you it wasn't working or that it was corrupt.  you can try a repair install and that could possibly get things back to normal, but not remove the virus.  for that, you will need to connect the hard drive to another uninfected computer and run a full scan.
May 18, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
System won't go past profile page..stuck
It seems that the Guest account profile is corrupted because of which you are unable to log in as like in previously.
In the Profile Login page, hold the Ctrl and Alt keys and press the Del key twice.
This will give you a window where you need to enter the User name and Password.
Enter the User name as administrator and leave the password column blank if you have not set any Password to the administrator account or enter the Administrator password if you have set any.
Now once you are loged into the Administrator account, create a new User from the Control Panel > User Accounts.
Set the required limitatios to the account like limited account or administrator account and log off from the administrator account.
Now, you should have the newly created user account available in the login page. Select it and you should be able to login.
Aug 11, 2008 | E-Machines eMachines Desktop PC
Dell Latitude D600 Notebook Logo
Alun Cox
