Question about Garden
How do I install an auger belt on Yamaha snowblower ys828
5 Suggested Answers
SOURCE: Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Posted on Dec 26, 2008
  • 26 Answers
SOURCE: Replacing the belts on a 20 year 8/26 MTD snowblower
you will need to take the housing off.
Posted on Jul 30, 2009
wireguy212
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
  • 371 Answers
SOURCE: We have a Huswana snowblower and the auger does
Sorry, your problem was posted to Sewing Machine category. If you are still having problems, you mnight want to re-submit to another appropriate category for help.
Posted on Feb 13, 2010
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Installed auger belt on my 421 snowblower and the auger turns all the time.
Sounds like the auger belt is too tight. What belt did you use? Toro 37-9080? If you used the right belt, there is an adjustment on the cable going to the pulley that pulls the belt. Follow the cable to where it goes into the side of the machine. There should be an adjuster. Loosen the adjuster so that there is enough free play so the auger does not turn when the handle is not pulled.
Feb 14, 2011 | Toro Garden
How to remove the belt from craftsman snowblower model C459 52560 MFG code 1/055/3-0079
Unfortunately like many other snowblowers you first need to seperate the auger/blower assembly from the drive/engine assmbly. Pretty straight forward after that. Make sure you put belts on the right side of the metal tab that cleans the back side of the belts when running or you'll they'll cut in two the first time you engage the auger
Dec 17, 2010 | Kitchen Ranges
How to change drive belt-Ariens 522 snowblower-model # 938017
Which belt? You are referring to the auger drive right? The self propell uses a friction disc drive.
The auger drive has two belts, and in order to replace them you need to seperate the auger from the engine (split) the blower.
Happy days.
Matt
Dec 13, 2010 | Garden
How do i change the auger belt on a honda hs 70 snowblower?
Remove the auger belt housing cover 4 bolts (10mm), if you are lucky, you can take the belt out, or just cut it. The slide the new belt between the auger and driving pulleys. there is a break pad under the auger pulley, so have someone engage the auger handle and put the new belt on the auger pulley. Or you can remove 10 12mm bolts and separate the auger and engine. Even though you have remove more bolts, it is easier.
Nov 26, 2010 | Garden
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
HOW DO YOU CHANGE BELTS ON TORO 824 SNOWBLOWER
you have to ssplit the snow blower in half to get to the belts. Its easy but make sure to replace both belts and also check the auger bearing they are known to wear out and the auger belt will not get tight. The bolts are on ether side behind the auger assm
Aug 20, 2009 | Garden
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
