Question about ASUS P4S8X-MX Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
Dear Sir,
              My ASUS P4S8X-MX mother board is not understand the CD-ROM and not boot from CD message not appear. When the mother Board and CD-ROM is attach, power on the comuter the following message is appear.
Boot Block Compatible Version Ver .020
Bad BIOS checksum starting BIOS recovery
Checking for Floopy.
Floopy not found!...
Checking for CD-ROM
CD-ROM not found!...
                              Please tell me explain above the problemn,what hardware,software or other devices problemn? I'm very quickly know. I should to the motherboard, step by step please explain and reply the following E-Mail Address.
                             I'm waiting for your reply letter.
        Thank you very much.
        Myo Naing
Re: Please Tell me, ASUS P4S8X-MX Problemn
The mothorboard is asking for the CD-ROM that came with the motherboard It recognizes The cd drive is there it just needs the cd-rom to update the BIAS
Posted on Dec 19, 2008
  • 51 Answers
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Posted on Oct 18, 2007
0 characters
3 Points
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
Lost the mother board cd of asus p5vdc-mx
go to the above link select your os and download the drivers
Apr 01, 2009 | ASUS P5VDC-MX Motherboard
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
Asus p4s8x-mx support CD
If you want a copy of the CDs contact Asus by clicking here and ask if they can sell you a replacement cd for your model.
Instead of getting a replacement CD you can download and run the drivers from Asus download page here:
DRIVERS for Asus P4S8X-MX Motherboard
Sep 05, 2008 | ASUS P4S8X-MX Motherboard
download your drivers here
Hello sir
Here is the web link
next time dont be so lazy and google it yourself!!!!!!!!!!!!!!!!!!
Aug 16, 2008 | ASUS P4S8X-MX Motherboard
Sound driver
go download the drivers from the following link
Jul 11, 2008 | ASUS P4GE-MX Motherboard
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Mar 10, 2008 | ASUS K8S-MX Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
ASUS K8V-MX Motherboard Problem
you need to check all of your drivers, as 1 it sounds like your Graphics driver is not working well at all 2. you are not able to access your CD drives as your IDE driver is not compatible with VISTA and needs reloading follow the prompts on the following web page to get up to date drivers from the maufacturer Download updated VIA Chipset drivers for K8M800 + VT8237R to solve CD drive problem Audio drivers
Oct 07, 2007 | ASUS K8V-MX Motherboard
ASUS P4S8X-MX Motherboard Logo
738 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
