Question about Sony KDF42E2000 42" HDTV
Problems with the power on a sony hdtv KDF42E2000
We replaced the lamp in the tv, but it does not turn on completely. Once we replaced the lamp, the motor runs for a couple of secongs and then it shuts down with the power light blinking red. What are we doing wrong?
    President:
  • 196 Answers
Maybe the probles is with the ballast. the ballast # is A-1247-118-A, no longer available, the replace ballast # is A-1247-19A, is the same.
Posted on Apr 20, 2010
  • Radames Pagan
    Radames Pagan Apr 22, 2010
    correction--The replace ballast # is A-1247-119-a
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony KDF-E42A10 cycling on and off
the best thing to first is to replace lamp ..lamp will also cause this..this will be the cheapest route to go first..Please let me kno and I will give you more info or docs from Sony...
Dec 14, 2007 | Sony KDF42E2000 42" HDTV
I just replaced the lamp on my Sony KDF-42E2000 TV. I am still getting a red horizontal line across the top two inches of my tv. What should I do to eliminate the line?
If you have a cable box hooked up try switching it to a different input. That might solve your problem, but if it doesn't then it's possible there may be a problem with the color wheel.
May 04, 2011 | Sony KDF42E2000 42" HDTV
Just replaced bulb turn on power and get three flashing red lights, help
a flashing code of three indicates a loose lamp door. make sure the lamp door is secure. the dooe ussakkt has a peace that stticks in a slot that trips a switch.
Mar 03, 2011 | Sony KDF42E2000 42" HDTV
My Sony KDF42e2000 goes on and off every 30 seconds. The picture looks good when it's on. Does this mean I need a new lamp? There are no "code" flashing. The power light is solid green when the screen is...
Yes, its symptom of weak lamp that has been reached to end of its life. If lamp has not been replaced in last 2-3 years, replace it to solve tv issue.
Thanks.
Sep 27, 2010 | Sony KDF42E2000 42" HDTV
My 42e2000 just said "lamp at end of projected life". I have had this TV for several years, have had it isf calibrated 3 times (the last time was 1 month ago). At that point, the technician said everything...
I recomend chnge the lamp now to avoid ballast problem after.and remember reset the lamp timer after change.for reset lamp timer press menu in the remote control ----setup------in the color adjust side find lamp reset ----a change a new lamp question appear--push yes and ok.
Apr 09, 2010 | Sony KDF42E2000 42" HDTV
I have 42in kdf42e2000 and it keep cycling on and off
If the TV cycles 3 times then shuts down or the picture goes on and off then I suspect you will need to replace the projection lamp. The part number for the lamp is F-9308-750-0. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Sony KDF42E2000 42" HDTV
Tv will not turn on and on the power light blinks red 3 times
change the lamp XL-2400 AND RESET THE LAMP TIMER AFTER.
Oct 02, 2009 | Sony KDF42E2000 42" HDTV
I have 42in Kdf42e2000 and it keeps cycling on and off. it stays on for 45 sec and the shuts off power light blinks for 42 times then it goes back on and the cycle starts again. Does anyone know what could...
Its symptom of weak lamp in TV, please replace lamp.
Lamp replacement procedure is easy and mentioned in instruction manual, if you need copy of manual, click Sony Support.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
You can buy replacement lamp from Sony Accessories Store under following part number..
F93087500 Lamp Block Assy XL-2400
Thanks.
Jul 09, 2009 | Sony KDF42E2000 42" HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Sony KDF42E2000 42" HDTV Logo
383 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
