Question about HP DesignJet 9000 InkJet Printer
Media misaligned reload media
Al inicar marca "check me lever load media" al poner el material aparece el mensaje "media misaligned reload media" el carro de los cabezales apenas si sale, no hace el recorrido y se regresa, la impresora no se pone en linea realmente no me deja hacer nada Gracias por su ayuda
3 Suggested Answers
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
Vue 2007 fusible de ventilador, al poner la cuarta velocidad de aire acondicionado se apaga.
Saturn vue 2007 el ventilador no se apaga se prende al momento de encender el carro y ya no se apaga
Jul 26, 2017 | 2007 Saturn VUE FWD 4
I have an airconditioner model APE08AKM1, but the compressor dont run, please help me
CUAL ES LA MARCA DE TU EQUIPO, TIENE REFERENCIA DE LOS ERRORES? EN LA PUERTA DEL EQUIPO?
Apr 29, 2014 | Heating & Cooling
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Yo mande mas de 10 mensaje de numero celular 584123362473 y 04125516627 y no me an dado ningun credito, por ejemplo:gracias, facebook le cobro 5.80vef a su cuenta de telefono. codigo...
compre token por zong mande 3 mensajes solicitando 121 token por zong me cobraron los msj y nunca me llego el codigo ni los tokens mi numero es 04268104327 de venezuela me mandaronun mensaje de zong discurpe por la compra contactar a support.vzzong.com y no consigo la pagina :S
Aug 19, 2011 | zong.com
Como poner el tiempo de un toyota corolla del 94 de motor 1.6 gasolina y lo ocupo urgente
tienes que poner el cylindro numero 1 a TDC. en el cyclo de compresion del cylindro. pon el dedo en el abujero de la bujia y que le de vuelta alguien al motor, y cuando sientas que sale aire, entonces estas en el cyclo de compresion, despues ponle un desarmador largo al cylyndro y cuando le des vuelta al motor fijate que llegue el desarmador a la posicion mas alta antes de que se vuelva a bajar y entonces estas en TDC. Ya cuando estas en TDC, ponle la cadena de tiempo al carro y listo.
Jun 27, 2011 | 1994 Toyota Corolla
Como poner el sensor de temperatura de toyota camry 89
PROBABLEMENTE ESTE DEBAJO DE LO QUE SE LE LLAMA LA ARANA (EL MANINFOLL) MUCHOS CARROS LOS TIENEN AHI PARA ESO TINES QUE DESARMAR TODO LO QUE ESTA POR ENCIMA DEL MOTOR PERO PRIMER CHEQUEA ALREDEDOR DEL MOTOR ES UN CABLE ELECTRONICO Y EL SENSOR SE PARECE AL SENSOR DE GASES
May 24, 2011 | 1989 Toyota Camry
Haw can change the band of distrubution?
ok sure you speak spanish because we says to timing belt = banda de distribucion. I will write in spanish :)
Lo que tienes que hacer con la banda de distribucion de tu Jetta 1994 es quitar las bandas externas de tu auto, luego de esto lo que tienes que hacer es quitar la polea del cigueñal para lo cual iras a requerir un extractor de poleas, ya que extraigas la polea del cigueñal y quites la tolva que guarda a la banda de distribucion y a los de los arboles de levas entonces gira con el maneral el cigueñal hasta las marcas del tiempo q deben estar marcadas en el motor o monoblock y/o en las tolvas, verifica estas marcas poniendo tu auto en punto muerto superior que es que el piston 1 quede hasta arriba lo puedes ver con un desarmador claro para esto tienes que quitar la bujia de tu auto del piston 1.
bueno ya que tengas esto prosigues a marcar la banda con alguna tinta o corrector tambien marca las poleas de los arboles o arbol y la del cigueñal, quita el tensor y va a salir la banda.
cuenta los dientes entre marca y marca y luego de eso marcalos en la nueva banda de distribucion. con el tensor de banda contraido pones la banda verifica que esten en sus marcas y luego vuelve a tensar la banda con su tensor.
si no sabes cuanto tensar solo verificar que la banda no debe doblar mas de 60 grados maximo 90 grados si gira mas entones esta floja.
ya puesta la banda verifica y dale 2 vueltas al cigueñal con el maneral y dado, si quedan en el mismo lugar las marcas luego de 2 vueltas completas de la polea entonces esta a tiempo si se atora se pone demaciado duro entonces las valvulas estan pegando.
vuelve a poner todo lo que desarmaste y listo!
Oct 16, 2009 | 1994 Volkswagen Jetta
HP DesignJet 9000 InkJet Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
