Question about Home Fencing
Trying to close gap between laminit flooring need to use sucition cup system floor is installed all ready need to close ends of flooring to gether.were can i bye this system.if there is one.
  • 52 Answers
I am in the flooring industry and I have never heard of this type of tool. The installers do you a pull bar and can be purchased an any flooring supply store. It is a tapping style unit that you can tap with a mallet to pull in the board.
Posted on May 21, 2009
How do you remove the lower center console on a 2000 Olds Intrique
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
Jun 10, 2015 | 2000 Oldsmobile Intrigue
How to fix laminate floor tiles gaps?
First, you need to get to one edge on the narrow side. (Where the slats run toward)
Second, you need a mallet and a hook tool.
Essentially, you need to put force on the edge to push the slats/planks together.
The mallet is used to put a lot of force on the slats to push them together.
The hook tool is inserted at the end of the row of tiles/slats/panels. The mallet is then used on the other part of the tool, so every hits force is transferred to the tile.
The slat/tile then will slightly shift toward the next one. Eventually this will put them together. Probably 4 to 8 mallet strikes should do on each row.
If this is an already installed floor, you may need to take the floor trim board off to get access to the edge of the tiles.
Jan 25, 2015 | Building Materials
Erratic garage door opener
It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
Dec 04, 2013 | Craftsman Sears Liftmaster Garage Door...
How can I prevent gaps in my hardwood floor?
There are a couple of ways to prevent gaps in your hardwood floor. Try to keep the humidity level in the room at constant 45 percent using an air conditioner or a humidifier. There is another way to prevent it, two weeks before the floor is to be laid, stack the flooring 4 bundles high leaving 7 inch space between the stacks which will allow your floor to properly acclimate.
Feb 06, 2013 | Building Materials
I have a 7950 Bissell. I can't get it to **** up from either the tools or floor area. I tried adjusting the knob on side but still no luck. Any suggesions?
First check to see if there is suction at the motor duct. If not contact you local BISSELL Authorized Service Center at http://www.bissell.com/customer-support/.
If there is suction,
a) Check if the small rounded window tabs on the Floor Nozzle are locked in
their mating slots and not inadvertently lifting the tank up out of place?
b) Check to ensure oval seal is in place at the top of floor nozzle window.
c) Check the diverter knob for proper setting and the diverter door opens and
closes properly. If no, and it does not appear to be broken, remove the floor nozzle window, open diverter door manually, keeping the flat
side of the door against the unit. Set the diverter knob on the tools setting.
Manually close diverter door until there is resistance, hold it in place while
turning the diverter knob towards the floor setting to lock it back in place.
Reinstall the floor nozzle window. (If diverter door will not lock back in place,
go to a BISSELL Authorized Service Center).
d) Check for the black foam gasket under the diverter door. Replace if
necessary.
e) Check floor nozzle window to ensure it is screwed down properly. If there is
a ¼" gap between the window, where it wraps around to the side of the
unit, and the base on the slanted section, reinstall window.
This gap can be eliminated by installing the tabs at the top of the window,
hold it in place, then push up from the bottom of the window to bow the
window, push it against the unit and then evenly slide it down into place.
f) Check half moon window to ensure it is screwed down properly on
CleanView models. The floor nozzle window should be lower to the floor
then the half moon window.
g) Make sure tank is not full on the outside of the bladder.
h) Check the tank lint screen for debris. Remove it to check.
i) Check tank lid and tank for damage.
j) Check float and baffle to ensure they are properly installed properly. The
baffle should be even with the top of the tank
May 29, 2011 | Bissell 7920 ProHeat Pro-Tech Upright...
I have 2003 f150 fx4 4 door.4 wheel disc. I had a brake line break on the driver side front. I ended up replacing the entire brake line. I have tried bleeding the system but can't seem to get pressure to...
when the brake pedal went to the floor, most likely the cup in the master cylinder went bad.. as long as you cant find any external leaks, replace the master cylinder.
Dec 11, 2010 | Ford F-150 Cars & Trucks
I have had new laminate flooring installed and taken old skirting boards off to be replaced.There are gaps around the doors that need to be filled.What do you suggest?
Well it depends on the situation, and I'm not sure of the situation by what you told me. If the gaps are in the laminate floor I would use wider molding to cover to the gaps. I have also found silicone caulking to work well in situations where there are gaps as it remains pliable and last a long time without cracking. Make sure if your going to use it you buy 100% silicone, and I have found GE brand silicone caulk to work the best in all situations.
May 31, 2010 | Rotary RotoZip XB-LF5 Laminate Flooring X...
When do I need moisture control for wood flooring?
You need moisture control if laying below ground level or on concrete anywhere as concrete is porous
Jan 03, 2010 | Crafts & Hobbies
Theer is a gap between the door and floor.
you may have to adjust the placement of the door opener, or the bracket could perhaps be adjusted on the top of the door. Usually you can adjust one end or the other to fix that problem.
Nov 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
I have a Sears shop vac.... i tipped it over this morning and the filter came off. No big deal, but there was a plastic or PVC cup inside, and i can't figure out whether the opening of this cup should...
You may need to better describe the cup on the filter, but if it has a handle on it, it's the end cap. The handle part will face the floor and you should be able to screw the cap on, securing the filter.
Sep 24, 2009 | Vacuums
Home Fencing Logo
100 people viewed this question
Top Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Home Fencing Expert? Answer questions, earn points and help others
