Question about NEC VT465 Multimedia Projector
Vt465 nec projector power light is orange
And lamp light is red
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Posted on Jun 23, 2008
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
  • 4 Answers
SOURCE: Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
Posted on Sep 15, 2009
The power light is yellow and status light yellow
it seems the lamp is failing ,the price of the lamp is USD130
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | NEC VT465 Multimedia Projector
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
I replaced the projector lamp and still no light what am i missing. all i get is a solid red lamp indicator and a orange power indicator.
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
Feb 10, 2011 | NEC VT465 Multimedia Projector
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
If the unit will not power up it sounds like you may have tripped the lamp timer. You will need the remote plug the unit in and hold down the menu button on the remote for 10 seconds. The red light should go off and the unit should fire up.
Thanks Projector Guy
Apr 21, 2010 | NEC VT676 Multimedia Projector
Mar 02, 2010 | NEC VT676 Multimedia Projector
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
Replacing new lamp
Hi - You can download the manual from the link below:
NEC vt465
Look at page E-30, make sure the cover is screwed up tight as there is an "interlock".
Most likely is the lamp hour meter needs reseting:
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 07, 2008 | NEC VT465 Multimedia Projector
NEC MT820 Projector
Press and hold the power button on the remote control for 10 seconds.
Sep 07, 2007 | NEC (MTLAMP820/1020) Projector Lamp for...
NEC VT465 Multimedia Projector Logo
50 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
