Question about La Crosse Home
Instructions setting atomic clock
It never works
SOURCE: instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Posted on Nov 20, 2008
  • 37 Answers
SOURCE: S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Posted on Dec 12, 2008
SOURCE: skyscan atomic clock model no 88902
Instructions for setting the clock can be found at:
http://skyscan.info/content/index.php?option=com_content&task=view&id=57&Itemid=40.
Posted on Apr 12, 2009
SOURCE: time zone setting on Medion atomic clock
Re: Median MD10954 time zone setting.
Press the MODE button but do not hold it in.
repeatedly pressing the MODE button will alternately display the DAY OF THE WEEK or the SECONDS next to the time.
With the DAY OF THE WEEK displayed, press and hold the UP button for up to 5 seconds. Each 5 second press of the UP button will move the time zone by one.
When finished, you may press the MODE once again to revert to SECONDS display.
Good luck,
ACTION from Cincinnati
Posted on Jun 12, 2009
SOURCE: I can't set the clock. The hands keep turning and
Look at the bottom right of the back of the clock and find the "M Set" button. Simply hold it down and the clock will move (very slowly). When it gets to the correct time, let go of the button. After that, the radio controlled shoul dcontrol should correct any minor differences in time.
Jim
Posted on Aug 11, 2009
Setting clock on 2N5 VOO(U)
Hello, AB -
Are you asking for instructions for setting a SioScan atomic clock, also called a SkyScan atomic clock? If so . . .
The information here may prove helpful:
https://www.hunker.com/13410966/how-to-reset-the-time-on-the-sioscan-atomic-clock
Best wishes.
Jan 16, 2018 | Home
Manual/instructions for Timex model#75324 atomic clock
Here is a link to the user manual: http://www.acurite.com/media/manuals/75324T-instructions.pdf
Mar 09, 2015 | Timex Atomic Digital Wall Clock
Instructions clocks sky scan mod88905
Hello
Get into this link. You can get user manuals for many models of Skyscan clocks there. OK.
http://www.atomicclocksstore.com/skyscan-atomic-clock-model-86931-manual
Nov 08, 2011 | SkyScan 86742 Digital Atomic Wall Clock
Time setting
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 19, 2010 | Sharper Image Wireless Caller ID with...
How can I set the timezone on my Sentry self-setting atomic clock?
Many Sentry product manuals can be down loaded from the following URL
http://www.sentryindustries.com/support/manuals.asp
The instructions for Sentry CR104 is located at the following URL
http://www.sentryindustries.com/pdf/instructions/CR104_instructions.pdf
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
Jan 09, 2010 | Sentry CR104 Clock Radio
Don't know how to set my atomic projection alarm clock. C17D3129 (WIC#628123) Pat Wood
No. I didn't "fiix" it. I only wanted to know how to set it. I have lost the instructions. Thanks, Pat
Aug 28, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Instructions for setting Sharp Atomic clock
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
22 people viewed this question
Top La Crosse Home Experts
David Burbee
David Burbee
Are you a La Crosse Home Expert? Answer questions, earn points and help others
