Question about LG Microwave Ovens
LG orbit and turntable will not turn.
Someone gave me an LG Orbit microwave oven. It works fine, except the turntable is not turning so we have to keep stopping it to stir food and or move it ourselves manually. Cannot make popcorn at all. How can I get the turntable to rotate like it should?
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
ginko
  • 19396 Answers
SOURCE: GE Spacemaker XL1800 Microwave
You need to take apart the oven and fix the turntable gear, then reassemble it, it is not a difficult job. Always work with power unplugged.
Posted on Aug 04, 2008
  • 78 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel R-1481 Turntable
It may very well have have damaged the turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On many Sharp models, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Be sure if you cook an egg that you puncture the shell first so it can breathe.
Posted on Mar 02, 2009
SOURCE: Hi I have an Emerson microwave oven MW8998B. The
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
Posted on May 15, 2009
LMA1560SB microwave--everything works fine (lights, clock, turntable) except does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
Turntable won't turn in the microwave
look for supply to turntable motor if supply is coming on motor and it is not moving it means motor is faulty
Jun 23, 2010 | Danby DMW1146SS Microwave Oven
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Microwave turntable does not turn
In microwave ovens, I have had the turn table motor unit become defective, or the power source to it has failed.
Jerry G.
May 15, 2009 | Hotpoint RVM1435 Microwave Oven
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
The turntable probably isn't on the spinny thing and that is what makes it turn- try lifting it up and putting it back on.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No longer turns
on the bottom of most units you can get to the turntable motor with some side cutters,cut the joins. pull the little flap off and there is your motor run a current through it to see if it turns(how much will say on the motor) if not turning there is your problem
Oct 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Mar 08, 2008 | Goldstar MV-1526 Microwave Oven
Microwave turntable won't turn
You will have to take it out and then take off the outer cover to expose the drive system for the turntable unless the items turns with the turntable removed. If it does then (and if it is belt driven) the belt may be worn and slipping. Anyway you look at it the cover has to come off to see what is happening.
Feb 08, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
