Question about Watches
I cant set the date on my versona watch
I cannot figure out hownto set the day and dste. The pin only clocksmonce
  • 4 Answers
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Posted on Nov 14, 2007
escapement
  • 2334 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Posted on Jul 08, 2009
escapement
  • 2334 Answers
SOURCE: Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Posted on Mar 31, 2010
Testimonial: "Thanks so much. I thought I had tried what you suggested already, but apparently I hadn't. The watch is now set correctly. Thanks again!"
How do you change the day of the week and the date on Vintage rose 6752
Push in that small indentation with a pin tip until it's on the date you want, quick , but took me 4 months to figure out...
Jan 12, 2014 | Invicta Mens 6752 Vintage Rose Dial Black...
Cant change the date
I am assuming the day changes but not the date. There is a halfway setting on the stem you pull two clicks to set time , one click to set day/date, turn one way for day of the week other way for date. If your actual date is sticking you can try going round and round with the hands (takes awhile) to set it! I have noticed the date is the first thing that goes on these watches. If that does not work it will have to be repaired by a watch repairman. hope that helps:)
Aug 28, 2011 | Watches
My wrist watch has been in a drawer for over a year. I want to wear it now. the time shows 6;13 and the date shows 8: 16. It is running correctly. How do I set it foe the correct time and date?
First you need to unscrew the crown (setting knob) of the watch. Turn dial from up to down (downwards), you will feel the knob loosen and then it will pop out gently.
Pull out the pin very gently and turn downwards to set the date. If you have a Day and Date watch, turn upwards to set the day of the week.
To set the time, pull the pin out futher and turn to set the appropriate time.
Finally push pin in and simultaneously turn upwards to screw back the pin.
Please make sure you push turn the pin tightly because most cases of Water Damaged watches are caused due to the pin being screwed up not tight enough.
Aug 17, 2010 | Watches
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
I can't figure out how to set the date.
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Apr 26, 2010 | Fossil BQ9183 Wrist Watch
I cant figure out how to set the time and date on an armitron mens M516 all sport 40/6753
I cant figure out how to set the time and date on the armitron instalite
Jul 08, 2009 | Bulova Watch
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Minicci sport watch problem...
I also have this problem and how do you remove the links? it's too big for my hand.
Dec 26, 2007 | Kenneth Cole RK5034 REACTION
Watches Logo
50 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
