Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Changed the spark plugs, new battery, new fuel filter, changed oil, drained and changed gas. Cleaned the wires and tightened everything up. Still wont crank at all though any ideas would be helpful.
    Problem Solver:
  • 4 Answers
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
Posted on May 19, 2009
Craftsman silver won't start
ground the spark plug to the engine block it should spark. sounds like you need to check the valves and push rods
Jul 04, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Gary
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 15.5 HP, Craftman lawn tractor. I'm having problem with it staying running. It will run just find for 20-30 minutes and then stop abruptly. I have changed the spark plug, oil, cleaned the air...
Check the Blade Safety Switch. Also check if the Carburettor requires a good cleaning and overhaul or not. After that check if there is any air leak or air in the fuel line.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel...
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
604 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
