Question about Welding Tools
Proarc 1150b whats the longest leads you can use on this model
I changed my spark plugs and wires and it won't start what's going on
When you refitted the ht leads you may have put them on in the wrong order. Not sure what order they should be but the longest lead will go to the furthest plug and the shortest to the nearest. Hope this helps
Oct 27, 2015 | Cars & Trucks
Tip
Finding shoes for ageing feet
Number of tips for finding shoes for ageing feet: 1. Ensure the toes don't touch the end of the shoe, allow a 1cm gap from the longest toe. 2.Shoes should not need "breaking in" they should fit comfortably from the start. 3. Ensure the toes don't touch the end of the shoe, allow a 1cm gap from the longest toe. 4.Ensure the toes don't touch the end of the shoe, allow a 1cm gap from the longest toe. 5.Ensure shoes are wide and deep enough to prevent heel slip. 6.Lace up, buckles or Velcro should hold the heel in place Velcro straps can be easier for arthritic hands.7. Slip on shoes can encourage the toes to 'claw' at the shoe to keep it on leading to discomfort, corns and calluses.
on Oct 27, 2010 | Clothing Accessories
Machine basting stitch
Basting stitch is the longest or second longest stitch available in the straight stitch menu. The choice is yours.
Nov 21, 2013 | Kenmore Model 385.16126200 Sewing Machine...
400 cb super4 coil leads what plug do they fit on
one coil feeds 1+4...the other feeds 2+3...
the longest lead will be for number 4 and the shortest number 1
Jan 27, 2013 | Honda Cb 400 Super Four Motorcycles
Have the 3gal model. For the longest the highest
your pressure adjust valve is stickn unless your bottom valve isnt shut all the way
Nov 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Trying to find a manual for a Pro Arc 1150B 115 volt/100 amp welder - can you help?
Go to proarcwelding.com . I didn't see a manual available,but they have a contact page. If anyone can get you one ,they should.
Oct 04, 2009 | Welding Tools
If you play stick arena what is the longest time you could be banned in that game
the longest time is unknown but the longest time is well ... u know... is WHEN YOUR PRESIOUS LABTOP OR COMPUTER BLOWS OR OVERHEATS AND NOT WORK ANYMORE IS THE RECORD of the longest time EVER!!!
Sep 13, 2009 | PayPal Accounts
Backfire issue
it sounds like you got one of the spark plug leads on the wrong plug,most honda have the spark plug leads numbered 1,2,3,4,no1 is the cylinder by your left knee,no4 is the one by your right knee,if they are not numbered see the length of the leads ,the longest ones go to the outside shorter to the inside cylinders,hope this helps
Apr 25, 2009 | 1999 Honda CBR 600 F(4)X
Running problem plugs and leads
the longest lead goes 2 the furthest cylinder, as they get shorter move back towards the distributor!!! all the leads are different lenghts! check the plug lead on the coil at the shock mount as it gives problems!!
Apr 19, 2009 | BMW 318 Cars & Trucks
Welding Tools Logo
53 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
