Question about GE Washing Machines
Wjre5550k2ww squeak During washing the machine has a squeak when the drum rotates back and forth.
SOURCE: Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Posted on Aug 22, 2007
SOURCE: Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel. 6b657f1.jpg
Posted on Jan 11, 2008
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
  • 6277 Answers
SOURCE: top loading washing machine drum is off center and
Hi from retired Englishman in SW France
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Feb 20, 2011
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Started squeaking when washing ( 3 yrs old)
Bearings squeak, rollers that help rotation of the drum squeak, then lock up, and are eventually worn down by the rotating drum. If a front loader, removing the front door panel should let you see the coaster wheels that support the front of the drum. Maybe a little oil there would help.
Jun 01, 2015 | Washing Machines
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Fisher paykel dryer DEIX2 squeaks when drum rotates
I've had the same issue with my FP washer, thanks for the tips!
Jan 17, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
Squeak in Kenmore HE 2plus front load washer when drum spins
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
