Question about Palm TX Handheld
Need to move contacts in Palm Desktop to new user name
My Palm TX has a user name of "misty". The contacts files on my desktop in Palm Desktop are in a file with a user name "PalmUser40". I need to either change the user name on the Palm TX to "PalmUser40" or change the user name on the computer to "misty". This way when I hot synch, my contacts will appear on my Palm TX
    Problem Solver:
  • 6 Answers
On your Palm Desktop, under username PalmUser40, select the category view of 'All'.  Then press Control + A to select all contacts. Then press Control + C to copy them all.
Then change the username on the upper right to 'misty'.  Then go to contacts, under category 'All', and then Control + P to paste all contacts.
This will most likely not keep all the category names, but all your contacts will be copied in.
Then hotsync to sync to your Palm TX.
Posted on May 20, 2009
Can's install SW on Treo 755p error "unable to locate users.dat"
users.dat is created in your named profile directory on the drive in the Palm folder. If it is missing, your computer can't sync properly to the device. Do a backup of your device using the palm desktop, this should recreate the file in your profile folder on the machine.
Oct 02, 2009 | Palm Treo 755p Smartphone
Using the desktop, is there anyway to move(either to the memory card or the PC) or delete files on a Palm TX. I apparently used to much of the devices memory and now I can't ge to the home screen(it...
If you're able to hotsync, then yes. In the desktop, delete notes or other items (Does the TX have voice memos? Those would be a quick way to free up a lot of space!)
Perform a hotsync, and your Palm should then have some free memory.
If you're not able to hotsync, then nothing you do in the Desktop will have any effect on the Palm.
But, I'm skeptical that this is the real problem. It sounds more like memory corruption, and a hard reset is going to be the real fix.
Sep 14, 2009 | Palm TX Handheld
They are probably in a format that the pda can not handle.
Sep 14, 2009 | Palm Tungsten E2 Handheld
Remove user name on Tungsten E
Here are the steps to removing username.
1. Open your palm desktop on your computer
2. On top left click on tools and then users
3. A new box will open highlight the username you want to delete, hit delete.
4. Done.
Aug 16, 2009 | Palm Tungsten E2 (Multilingual) Handheld
My Palm desktop program on my laptop lost half of my contacts
Ok, do a hard reset in you pda, in your PC, using you palm d., open you user files, export your adresses and memos; then create a new user and import all this data and do a hotsync
Apr 24, 2009 | Palm Tungsten T2 Handheld
How do I export contacts from a Palm 650?
First thing what is your new phone you using now?
If still the same palm operating system,what you need to do is just 1.export your contact from your palm desktop.After that you create a new ac for your palm desktop then import the file you export just now to the palm desktop again.If you are using windows mobile repeat the number 1.then go to your active sync user ac and import from the file you export just now.
Dec 28, 2008 | Palm Treo 650 Handheld
Palm to iPhone
Assuming you are using Palm desktop, have an email account, and can receive emails on your iPhone:
1) Open Palm Desktop on your computer and click on Contacts.
2) Click on Categories and select "ALL".
3) Go to Edit and click "Select All" (all contacts should be highlighted)
4) Go to File and click "Export Vcard"
5) A dialog box will prompt you for a file name. Use what every name you prefer, but remember the file name and location. Your contacts will all be saved as a vCard file (vcf)
6) Now go to your email account and send yourself an email and "attach" the file you created from step 5.
7) On your iphone, receive the email from step 6 above. Scroll down to the bottom of the email and you will see the attached file from step 6 above.
8) Click on the attachment and you will be prompted by iPhone to add the contacts to your contact list. Follow the intructions.
Should work like a charm! [There are other ways of exporting from Palm to the iphone by exporting from Palm to a CSV file and then importing, after mapping fields, to either a Windows Address Book file or an Outlook (not Outlook Express) file. The advantage is the ability to sync on a batch basis with your iphone.. helpful to quickly add changes/new records to your iphone. But the vCard method outlined above is easiest]
Dec 22, 2008 | Apple iPhone 3G
Palm OS-based PDA freezes up
If you’re not sure what file or application is causing the problem, you’ll need to perform a hard reset. Before you do this, be sure to perform a HotSync so your data is properly backed up (the hard reset will erase all data on the PDA). To perform a hard reset, press the power button while performing a soft reset. Replace the power button when you see the Palm/PalmOne logo and press the Up button when prompted.
Next, find your Backup folder on the desktop. You’ll usually find this folder located within your user folder, which is usually located in either C:\Program Files\Palm, C:\Program Files\palmOne, or C:\Program Files\Handspring. Your personal folder will resemble the user name you selected for your device. If you used your first and last name, for instance, your user folder will likely be the first six letters of your first name followed by the first letter of your last name. Rename the Backup file to Backup.old and HotSync your Palm to restore personal data. Because you renamed your Backup folder, no applications or additional files will be restored at this point. Instead, an empty new Backup folder will appear. Move applications from your Backup.old folder into the new Backup folder one at a time and HotSync your Palm. After each HotSync, try to reproduce the problem. If the problem doesn’t reappear, move on to the next file. Delete any files that cause a problem after they are moved onto your PDA.
Enjoy! Pls.rate me if it's done. Thanks.
Kindly regards,
-micro
Feb 29, 2008 | Best Software ACT for Palm OS - Instantly...
Intellisync problem
First, uninstall all software, Palm Desktop and Intellisync. Move the user files to the desktop. Reinstall all software. Try a sync. If this doesn't work, move the user files back to the proper location. Then uninstall all software, Palm Desktop and Intellisync. Now do a hard reset of palm unit. Try sync-ing.
May 18, 2007 | Palm Treo 650 Handheld
Palm TX Handheld Logo
144 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
