Question about LG Dryers
Dryer will stop .a code appear d90
DLEY1202
I have an LG Dryer and keep getting a error message D90 after running for about 10 minutes
D90 means the dryer thinks the vent duct is 90% blocked. Be sure the vent hose is not kinked behind the dryer. I've even disconnected the hose from the dryer and hooked up my leaf blower to blow out the vent as it develops more air pressure than the dryer does.
Here's a great video describing the error code: https://youtu.be/yL7Oq4lCadw
Good luck. Hope this helps.
John
Mar 22, 2015 | LG Dryers
Why does DLE4870W dryer keeps stopping with d90 error. but their is no blockage of air flow.
Check the link first before going forward!
The next step is more involved and you may want to call for service. Normally you will find a wiring diagram attached to the dryer, take a look underneath or some are found by removing the back cover. Take a look at the wiring diagram to see if there is a temperature duct sensor wired in, I would suggest changing the senor, but only after you check the link and call the support center found at the link!
Looking for Answers about LG Electronics DLE4870W
Nov 29, 2014 | Dryers
D90 won't work. Blinking Clock in top LCD panel.
First, turn the camera off and then remove and reinstall the battery. Turn the camera back on. If the clock and battery icons still appear, try resetting the clock. If this doesn't work, contact Nikon technical support at www.nikon.com and see what they have to say. It may require a repair but determine if the camera is still under warranty. If so, Nikon may repair it at no charge.
Jun 13, 2014 | Nikon D90 Body Only Digital Camera
Lg dryer error codes
Duct is plugged it is heating up. the vent needs to be cleaned.
Oct 12, 2013 | Dryers
"error code" r33
Is this keeping you from shooting? Normally this is an informational message telling you how many more shots you can take in the current burst before the buffer fills up and the camera has to stop shooting and write to the memory card.
Sep 09, 2013 | Nikon D90 Digital Camera with 18-105mm...
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
Got my Nikon d90 for 3 months now,but encountering error problem with my Nikon D90 w/ 18 105 vr lens.sometimes when i'm ready to shot it appears on the Top LCD,error F--,..Pls. help guys...Thanks
This is a common problem with this camera/lens conbo. I "solved" it by removing the lens, then reinstalling it - but hold the lens release button down, and rotate the lens a nuber of times (in the camera body) before releasing the button. It appears that the issue is poor electrical contact between the lens and camera body. If there is a poor contact, the camera will not know if thereis a focus and will lock the shutter release. With this poos contact, the camera will only fucntion in manual mode
Hope that this helps
Aug 31, 2010 | Nikon D90 Digital Camera with 18-105mm...
Dryers Logo
18 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
