Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I have a Raypak 2100 digital, I have it professionally open and closed. The company opened the pool, but the heater does not come on. While looking over the heater(which I know nothing about)I have noticed water dripping from a small plug on the far side(away from the pool pumps and pipes) inside a small hole, there is water dripping from this small knob. The gas line is also in the off position. Was this something the company overlooked? Or is there some sort of security feature that would keep it from being operable because of the water drip? Thanks!
  • babs2464 May 19, 2009
    Yes, I have checked the on/off switch, also checked the breakers.
    Problem Solver:
  • 10 Answers
That water leak would not keep the heater from coming on is there power to the heater check and see if it is on there is a switch on and off switch on the side of the heater, check and see if it is on
Posted on May 19, 2009
  • noe Duran May 21, 2009
    the heater gas line must be on the on position for the heater to turn on. and as for the water leak are you losing any water to the pool if you are it might be from the valves gasket .the water drip would not have anything to do from keeping the heater from turning on
Raypak 2100 206A worked 3-4 times after replacing circuit board, now error code GVO, gas valve open, what does this mean and how do I correct it?
check to see if you have proper gas pressure at unit most people think its the unit but mostly it is too small a gas line or too small gas meter call gas company
Jul 07, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Why does Heater keep shutting off and on. Tech says everything looks ok by milli volt readings
problem is you either have a poor neutral connection, one of the safeties is opening and closing at times, or the gas valve is faulty
Jun 30, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
HOW DO YOU REPLACE WATER TEMP SENSOR ON RAYPAK 2100 336A GAS POOL HEATER
open side by plumbing it has wire going to it and threaded into header
Mar 30, 2013 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 pool heater " PRS " diagnostic reading What does it mean and how do i correct it
This is low pressure. Start by checking your baskets for clean then be sure to clean the filter. Then make sure the by-pass valve is closed and lastly if your pump basket is cracked or broken check to be sure nothing is clogging your impeller.
Sep 19, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
379 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
