Question about Nautica Starboard 25" Rolling Expandable Upright Suitcase Color: Black / Grey
Nautica suitcase handle stuck closed
Handle stuck down - closed
Calvin Klein Suitcase Nolita 3.0 20" carry on spinner handle replacement?
Get in touch with Calvin Klein near you I am sure they will be able to help.
Mar 07, 2016 | Calvin Klein Suitcase, 21 Bromley Hardside...
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
Can you fix a samsonite suitcase handle?
what happen to your suitcase handle?
Apr 05, 2011 | Garden
Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
Feb 17, 2011 | 1998 GMC Jimmy
I cant fold the scooter down to fit into a suitcase
There are 3 things that can fold.
The handlebars collapse from the lever on top of the handle bar, that allows each handle to pull out.
The lever at the base of the handlebar allows it to retract.
And the lever at the base of the steering allows the body to fold against the steering shaft.
May 28, 2010 | Razor 'A' Scooter-Clear
My suitcase won't release the pull handle so I may roll it about.
Try using a small amount of oil or silicone lubricant to free it. Sometimes you can push quickly and then pull to extract it.
Jul 10, 2009 | Luggage & Travel
How do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Jan 24, 2008 | Zooper CoolZone Sport Stroller
Nautica Starboard 25" Rolling Expandable Upright Suitcase Color: Black / Grey Logo
409 people viewed this question
Top Nautica Home Experts
Donni Steen
Tom Chichester
Are you a Nautica Home Expert? Answer questions, earn points and help others
