Question about GE JGRP17 Gas Single Oven
Ignitor dose not spark on one burner
Ignitor does not spark on one burner
  • 6,784 Answers
Hi. these ignitors are really easy to diagnose. all to do is inspect the wires leading from the control to the ignitor/burner assembly. if the wires are in good condition and, you know for sure that your control is fine. simply replace the failed ignitor.
Posted on May 21, 2009
Ignitor wont stop after burner is lit
if its a hot surface ignitor it stays on as long as theres a flame present as in heating the oven,if its a spark type ignitor then the switch or control board controlling the board has a defect
Nov 19, 2012 | Baumatic Ovens
My bottom burner dose not come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Dont know how to get to the ignitor to remove it . its a kenmore gas stove the broiler works but the the oven dose not get hot on bake..
the bottom of oven has a removable cover . two screws in the back l & R then lift out the cover from the back side and the burner flame spreader in under that cover . Remove one sometimes two nuts form the flame spreader and in the center on the back of the burner is the ignitor . remove the two phillips screws and lift out the ignitor. make sure the wire's are disconected in back . reverse this prorcess and you have completed the instalation .. mm
Jul 11, 2010 | Kenmore Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Clicking of ignitor when burners are off
    Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
    Gas Range RepairBurners Keep on Clicking
    heatman101
    hgddg
    Sep 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
    Hi, I replaced the right side ignitor module and now the ignitors spark vigorously and the burners light but the ignitors won't spot sparking and sometimes keep sparking several seconds after I turn off...
    There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
    thanks.keep updated and please do accept the solution.
    Sep 18, 2009 | Viking 30" Professional Select Built-in...
    VDSC 365-40, Suspected right side ignitor box bad. Repairman came, obviously didn't know Viking, tore into unit and confirmed bad ignitor box. Estimated $450 to repair. I put in new box myself. Works...
    You have to identify the thermocouple by the flame. Some units run sparks constantly to insure that tha flame stays lit. If you see the thermocouple bulb by the flame it is bad and needs replaced (he may have bypassed it also let me know)
    http://www.vikingrange.com/MEDIA_CustomProductCatalog/m10110_viking_primer_2005.pdf
    It would be helpful if you have a multi meter. Sorry you are having trouble with the repair man. I hope I can talk you through this but if he has made a mess it could be 10 times more work for you. Txtooltime@aol.com
    Sep 02, 2009 | Viking 30" Professional Select Built-in...
    Ignitor on Frigidaire model PLCS389DCC is not working. How can I replace it.
    There are a couple of ways you can resolve this issue, depending on what isn't working. As it's difficult to determine by the brief description of the problem you're having, I can't tell if the main spark (ignitor) module is the faulty component, or if you need to replace a specific ignitor/orrifice assembly for one or more burners.
    If none of the top surface burners are lighting when you turn them on, it is most likely the spark module that needs to be replaced. If it's only one burner that is not lighting, then you'll need to replace that burner's ignitor/orrifice assembly.
    To get at these components, all you need to do is lift up the top range surface to expose the burner assemblies and the spark module. Be sure to turn off the gas line and unplug the range from the electric outlet to prevent any shock hazard, etc. Removal and replacement can be done with simple hand tools and by simply unplugging the electrical plug on the spark module.
    Here's a exploded line drawing showing the components, part numbers, and a price list as well. You can order the part(s) needed online as well.
    http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PLCS389DCC&productCategoryId=0122008&brandId=1428&modelName=DUAL-FUEL-RANGE&diagramPageId=00002&componentDescription=BURNER&documentId=R0504191&backToLink=Return%20to%20Sub%20Components%20list
    Hope you find this Very Helpful and best regards!
    Aug 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
    The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
    Aug 27, 2009 | Ovens
    GE JGRP17 Gas Single Oven Logo
    109 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
