Question about Yamaha RXV367 Receiver
Surround sound speakers fade in out - Yamaha RXV367 Receiver
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
I have a Jensen DVD media pro 5000 hooked up to a ViewSonic TV in my Camper Trailer. Camper Trailer was purchased with DVD Player and TV in it. At night, due to child sleeping, I would like to be able to...
hi yes you can do this press AUD button near the on/off/volume control momentarily to step through the following audio adjustment options volume, bass,treble, balance (left to right) and fader (front to back). when the desired option appears in the display, rotate the volume control knob to adjust that audio feature. When no adjustments have been made for three seconds, the unit will resume normal operation. so you can fade the speakers to however you want them...hope this helps
Aug 03, 2010 | Audio Players & Recorders
Sound is chopy
What is the source of the choppy sound? Cable box? When you say it fades do you mean it gets quieter or does it just blink off? Digital signal problems will cause the latter. You might check the cable box or call your cable provider about it.
Apr 03, 2010 | Mitsubishi WD-65731 65" HDTV
RCA 5.1 Surround Sound Receiver Sounds fade in and out
chk how you are hooking up the speaker polarity minus to minus and plus to plus.
Oct 17, 2009 | RCA RT2250 System
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Vizio lcd hd--sounds fades and then no sound after 10 minutes
Sue, I had same problem. I worked around it though, and glad I did. I used a computer sound system (sobwoofer, 2 speakers, power supply) and used the headphone output as the speaker system's input. Now I have surround sound controlled by the remote. Great for the kitchen where we all sit around and watch movies.
Apr 04, 2009 | Vizio VX20L 20 in. LCD TV
COLOR SHADOW
that is called a magnet effect it means u have a strong current some were do u have a cd player or speakers to close surround sound to close if so move them away till it fades
Jul 05, 2008 | Panasonic PT-51HX41 51" Rear Projection...
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Yamaha RXV367 Receiver Logo
14 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
