Question about Little Tikes Gas N Go Mower
Pull cord on Little Tikes Gas N Go Mower
How to fix the pull cord of gas n go mower toy
Blackberry_U
  • 223 Answers
SOURCE: little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Posted on Jun 15, 2009
0janet0
  • 8 Answers
SOURCE: Need replacement decals: Little Tikes Van & older Cozy Coupe.
i have seen a few replacement stickers for such items on Ebay.
Posted on Apr 19, 2010
  • 906 Answers
SOURCE: we need tires for the little tikes ride on toys
good day,
hope this link below answer your query.
toys
Posted on Jul 28, 2010
SOURCE: I'm looking for the charger
you can get one here for $30 http://www.funcreation.net/rhino1.html
Posted on Sep 07, 2010
SOURCE: little tikes bike trailer pulls to side
Look under trailer and see if the axle is loose or disconnected on one side. That would keep it from running straight. Look it over while you have it upside down. It will probably be something obvious.
Posted on Sep 07, 2012
My Toro mower won't start. The cord will not allow me to pull it out all the way. It seems to be caught on something.
Disassemble the starting mechanism and remove the snag in the line that is preventing you from pulling cord all the way out. Till you do that, you will be pounding salt.
Nov 01, 2015 | Toro Garden
How do i fix the cord on the lawn mower sk that it makes noise and retacts ?
you have to remove the bottom cover on the mower and remove the cord compartment , its black, then open up the compartment and you may find, like I did, that the little plastic gears in side are broken and the broken parts are what is not letting the spring retract the cord, I fixed mine after removing all broken parts but it only makes the noise 10% of the time, which is not such a bad thing.
Mar 23, 2015 | Little Tikes Gas N Go Mower
Travelling with a push mower in the car
not sure what you are asking
but if you want to put mower in car drain gas or run it all out
try to keep it as flat as possible, the oil will go into cylinder if you dont
remove from car pull the spark plug pull cord a couple times replace plug and gas
Apr 21, 2014 | Mtd 22" Yard Machine Push Mower
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Pull cord is stuck
Take off your cover to the pull cord, the cord probably just got wrapped around the pulley. If you run into trouble with taking off this cover go to smalleng.com they will walk you through the process off pull cord removal and installation. Good Luck PAL.
Jun 11, 2010 | Poulan Pro 22inch 625 Series Briggs ...
I have a little tikes 451 K Hummer h2 riding toy,
Hi Susie,
There are several options available.
There are numerous new chain stores popping up that specialize in batteries only. Batteries Plus, Batteries Only, etc.
These type batteries are usually sealed lead acid. So another alternative is an auto parts store for a motorcycle battery or a lawn garden dept, for a riding mower battery.
Just bring the old one with you to get the size right. You want to make sure it fits and the terminals should match.
Best regards
Mike
May 06, 2010 | National Little Tikes Hummer Yellow
Little Tikes Gas N Go Mower Logo
497 people viewed this question
Top Little Tikes Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Little Tikes Garden Expert? Answer questions, earn points and help others
