Question about Konka K2788U 27" TV
I have a konka crt tv model kp29ek601l2. when the power cord is inserted immediately the red lamp (indicator light) blinks twice and remain off. i cannot find a service/repair diagram or schematic. ca
There is a power problem with this tv. when the power cord is inserted into the AC outlet, the indicator light/lamp blinks two or three times and remained off. i check all components in power section they seems to be ok. please give me a clue. i have no service information, service diagram or repair manual. i have no where were to find information. please help. thank you
snakehead
  • 1074 Answers
SOURCE: red light blinking
If the tv is a dead set with only as you say the red light blinking, then your tv has a defected power supply or related circuit.if the screen light up with no sound then the tv is having a problem in the IF circuit or also the power supply.in either case you will have to call a tech to look on your set to repair it.good luck
Posted on Apr 24, 2007
  • 236 Answers
SOURCE: chassis kp2771uy, wont power up
If you have a switching power supply then you may have a problem with it. Also maybe a short on its load. The relay may be used only to de-magnetize the pic tube. If the set is also controlled by a micro processor then the stand -by voltage could be missing. There are so many possibilities that it's difficult to tell exactly what is happening. These are only a few things that may be wrong. Stargazer
Posted on Jun 02, 2007
SOURCE: How to unlock my Konka K2001UM TV
I cannot find the manual, it should be lost. Any more suggestions?
Posted on Jan 17, 2008
SOURCE: MY KONKA MODEL KLC 1508U
i have no picture and no sound. the tv does not turn on. anybody please help. the set is only 3 years old. thanks
Posted on Aug 16, 2008
SOURCE: No Konka TV Codes on Uni. Remotes
Hey everyone if you are trying to find the code for your konka tv on philips universal remote it is : 0208. My fiancee just played around with codes and figured this out. so your code is 0208..
Good Luck!!
Posted on Jun 28, 2009
Power failure and now tv won't turn on just has a blinking red light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 09, 2013 | Konka K2038U TV
Flashing red lamp light on front of my sony tv model # kdsr60bxr1/ no picture , no sound
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 14, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Three digits code universal remote of konka k1391u 13" TV
Hello
Three digit universal remote code for Konka TV are:-
203 208 219 306 317 417
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV each time with its front panel power control switch [NOT BY REMOTE CONTROL HANDSET], and wait for at about 30 seconds, between switch OFF and switch ON, before trying an other code.
OK.
Dec 20, 2010 | Konka K1391U 13" TV
Remote control for konka K2979
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your TV, Konka is listed in its codes. The codes and entering procedure are given:-
Codes For Konka:-
0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
Dec 15, 2010 | Konka Televison & Video
I NEED A CODE FOR THE REMOTE AND TO KNOW WHAT KIND OF REMOTE WILL WORK FOR MY TV. PLEASE
Hello
Your Konka TV can be programmed with Philips Universal Remote control MODEL [CL 034]
The codes are
0906 0702 0203 0306
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK
Nov 22, 2010 | Konka A2781U 27" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
My Konka model KLC-1508U tv will not come on there is no red light that shows it is off
May 11, 2007 | Konka K2001UM TV
Konka K2788U 27" TV Logo
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
