Question about HP Pavilion DV5000t 1.6GHz Core DUO Centrino 1GB 80GB DVD+RW DL 802.11g 15.4" WXGA Brightview (No Op... (EZ398UA) PC Notebook
From play back devices option pc speaker and headset option has disabled,how can i get it back.
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
Hi. I have used a used speaker recently, after using the speaker, I can not use the headset and the speaker are not working anymore, there is no option in control panel (sound) to active the laptop speaker...
I assume you have windows 7
1. Right click on the speaker icon in taskbar and select volume control options.
2. put a check mark on "All devices currently playing sound".
3. Make sure you have "The default communication device unchecked".
4. place a check mark on speakers/headphones
May 02, 2011 | Computers & Internet
When i plug in my logitech headset whitch is usb plugin the music plays go over the headset.But when I unplug the headset music does not play over the speakers.How do I fix this so it playes over my...
Start - Control panel - Sounds and Audio devices - Click on the "Volume" tab. Check that the device volume is included in your volume control (Advvanced - Options - Properties)
Also check your speaker Volume and Settings.
May 16, 2010 | Microsoft Windows XP Professional
Need audio output device
Hello...
Full details about sound issue in my website...
www.sureshayyar.110mb.com (Support page)
As an alternative u can do this (i am using this solution till date)
If u cant install the sound driver correctly, just buy a " USB Sound Adaptor" and connect it to the USB port and connect the speaker sound jack to the sound port in this adaptor....u will get back the sound....also keep in mind that u " may " have to disable onboard sound in BIOS, u may also have to make changes in the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option... Click the drop down button and select the "USB Audio Devices/Headset"
You can get it in Ebay for $1 to $4 or google it to locate a place near u......
This is the one i am refering to(I bought it in Ebay for 1$)....u can buy something similar also....there are many available mfd from China, just plug and play on your USB port....
If you find this solution useful please leave a feedback and rating to this solution.
Regards....
Mar 21, 2010 | Office Equipment & Supplies
My HP Pavilion Entertainment PC has lost all sound. The drivers (High Def Audio Device and IDT High Def Audion CODEC) are shown as functioning but there is no sound from the computer speakers or plug-in...
Hello...
Regards....
All the best, my dear friend....
Mar 03, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
I have the headset with the jack hook up not usb and I would like to know how to get music to come through my computer speakers while I'm talking on my headset and hear the person I'm talking to through my...
You are using one sound device at a time, this is not possible, if you like to be able to hear from headset and play music on your pc at a time, you must have a USB Amplifier and Headset (eg: GN Netcom, Avaya, etc...)
first you must set your Media Player's Option to Devices>Speakers>Audio device to use> DirectSound of your PC.
The other one is your are using a program to talk to other people, that program also has a feature to select the Audio devices to use, you must select that other device like my example above.
Hope this is clear enough to help you out.
Oct 21, 2009 | Computers & Internet
Headset & speaker both are playing at same time
Most probably headphone socket in the laptop is dirty. Spray some WD 40 or replace it.
May 20, 2009 | Logitech 250 Headset
I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Jul 22, 2007 | Logitech 250 Headset
HP Pavilion DV5000t 1.6GHz Core DUO Centrino 1GB 80GB DVD+RW DL 802.11g 15.4" WXGA Brightview (No Op... (EZ398UA) PC Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
