Question about GE CleanSteel GSL25JFTBS
GE gsl25jfte bs water dispenser makes noise when getting water
tech master
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
SOURCE: Water and ice will not dispense
I had the same problem. I followed stills' suggestion and used a weed **** wire to push through the water spout. The weed **** did not go past more than 2-3 inches. Then I emptied the ice bin, used the hair dryer right close to the spout both from the outside and from the inside of the freezer door. After about a couple of minutes it started working! Now, just to check if the weed **** wire will go in more than a few inches I pushed it through. Now I was able to go well past 6 inches. So, before even you start addressing this problem try pushing through a weed **** line and if it is blocked then your problem is in the door. If not, then the problem may be in the reservoir at the refrigerator side.
Posted on Jan 01, 2009
SOURCE: GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Posted on Feb 05, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Posted on Nov 19, 2009
  • 106 Answers
SOURCE: GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Posted on Mar 29, 2010
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
I have a GE side by side freezer/refrig, Model GSL25JFP-BS 4 years old. The water dispenser does not dispense water when the drink lever is pushed forward. Water supply thru the filter to the bottom of...
This is common due to the fact that your GE uses a pinch valve that eventually collapses the water tube. You will need to open the panel to access the valve and cut the old hose, then feed a clean piece back to the same place on the valve. There should be some excess hose present for this in the chamber.
Mar 09, 2010 | Refrigerators
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Frig GSL22JFTA BS
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Oct 08, 2009 | Refrigerators
I have a ge gsl25jfta bs, it is a frost free refrigerator but recently it is developing lot of frost around the water dispenser area(inside). It started when my water dispenser had stopped working and i...
Sounds like the flapper is not shutting completely. Open the door and look into the door flapper hole from the inside. If its not closed its either stuck (push closed from outside) or broken. If broken you will need part replaced
Oct 05, 2017 | GE Refrigerators
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
GE CleanSteel GSL25JFTBS Logo
24 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
