Question about Sanyo Televison & Video
Turns on but not the screen
The white light comes on down the right side of tv but screen doesn't come on..
jdbouncer
  • 72 Answers
SOURCE: Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Posted on May 02, 2008
  • 927 Answers
SOURCE: hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Posted on Aug 17, 2008
VOTIT
  • 2071 Answers
SOURCE: panasonic plasmam troubleshooting
The condition of your TV called power supply overcurrent shutdown that"s why you hear a click. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating . Although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Oct 10, 2008
SOURCE: Element FLW-1920B TV won't turn on or turns on then shuts down.
Try using a Baseball Bat, Worked for me. :)
Posted on May 26, 2009
diodeic
  • 1622 Answers
SOURCE: The red light to the
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help in solving the problem......
Posted on Jun 09, 2011
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
Polaroid LCD tv power light coming on but screen is not lighting up and no sound
DOES YOUR "POWER LIGHT" TURNS BLUE? IF NOT, IF STILL RED, YOU DONE! SYSTEM MODULE IS GONE!
OK: RELAX AND START WITH POWER SUPPLY MODULE. TAKE 3 MACHINE SCREWS(BLACK) OUT, RIGHT ABOVE YOUR IN/OUT CONNECTORS. YOU NEED TO RELEASE PLASTIC COVER, WHICH HAS A BIGGER SCREW IN A MIDDLE. TAKE ALL THOSE SCREWS OUT AND SLIDE PLASTIC GRILL DOWN, TILL YOU BE ABLE TO PRY IT OUT. THEN: SEE THE METAL SHIELD? ANOTHER 3 WHITE SCREWS AT THE VERY BOTTOM TO REMOVE.NOW, PULL IT OUT TOWARDS YOURSELF.NOTE: IT GOES INTO SLOTS AT THE UPPER SIDE. TAKE IT AWAY AND THROW IT OUT! DON'T USE IT ANYMORE! IT LACKS VENTILATION, THAT'S WHY YOUR SET QUIT!. LOCATE POWER SUPPLY BOARD(UPPER ONE), WHERE POWER CORD CONNECT TO. IT HAS 3-5 PLUGS. ONE TO THE RIGHT(2WIRES) THE REST AT THE LEFT SIDE. LOOK FOR BLOATED CAPACITORS, FIRST. FOUND NOTHING? SOME HAVE BALLAST BUILT INTO. HAS 2 18 PIN IC CHIPS ON THE LEFT SIDE AND THICK HV VIRES GOING TO THE PLUG. IN THIS CASE, YOU MUST REPLACE THIS BOARD.
IF NOT, MOST LIKELY CAPACITORS ARE THE PROBLEM.
GOOD LUCK,
ALEX'S TV.
Apr 06, 2010 | Polaroid FLM-3232 Television
Generic problem for all Flat Panel Televisions Plasma TV turns on
if I were you I would move the TV to a place where it would get more air to the vents of the TV so the heat buildup would be less.
Jan 10, 2010 | Maxent MX-42V1 42 in. Plasma Television
Televison & Video Logo
10 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
