Question about Mr. Heater Big Buddy Heater
How do you oil bearing on mr heater big buddy
SOURCE: Mr Buddy Heater Flameup on ignition
It sound like the pivot inside the regulator is damaged. I think that you will need to replace the regulator.
Posted on Jan 05, 2009
kapishtech
  • 2272 Answers
SOURCE: Mr Buddy portable heater Model
Turn the valve counter clock wise to open in and clock wise direction to close it.if its got stuck on any position,then move it on both direction and then move counter clock wise to open the valve. Check out.Keep updated.Thanks.
Posted on Aug 31, 2010
  • 308 Answers
SOURCE: how big of a breaker
It looks like a 15 amp breaker would be fine, here is the spec sheet
http://shopfnc.com/pdffiles/mhu45spec.pdf
As you can see the unit only pulls 3 amps.
Hope this helps
Posted on Nov 17, 2010
  • 182 Answers
SOURCE: mr. buddy heater- pilot light goes out when i
would try to replace the thermocoupler for the pilot light and this should cure the problem.
Posted on Dec 22, 2010
  • 125 Answers
SOURCE: when I press down and
When the pilot lights continue holding the button down for a full minute and then release. It should stay lit then to allow you to turn it to the on position. If the pilot will not stay lit after holding it for the full minute, then the thermocouple will need to be replaced.
Hope this helps.
Posted on Sep 16, 2011
The on & off switch for the fan----the switch on or off which position is correct
I have the "Big Buddy" heater and the switch is on top, if it is clicked down toward the front of the heater, the fan is on (little yellow dot), pushed back, the blower is off.
Nov 06, 2015 | Mr. Heater Mr Heater Portable Buddy...
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
Mr heater fan starting to make noise when starting
try taking apart fan housing & look to see if fan blade is scraping the housing. next look to see if fan blade is secure to fan motor shaft.next look to see if fan motor bearings are worn egg shaped and try oiling fan motor bearings with sae 30.
somewheres amoung all this inspecting of the fan motor, you will find the cause of the problem and learn what new parts you may need to buy to fix it.
Jan 17, 2013 | Mr. Heater Big Buddy Heater
When I press down and turn the know the pilot lights but as soon as you let up on the knob to turn it there is a click and the pilot light goes out.. This is on my Mr. Heater Big Buddy
Hope this helps.
Sep 16, 2011 | Mr. Heater Big Buddy Heater
Im on my 2nd big buddy and both of them the fan has gone out, the first on went in a week, and this one last a couple of months.
fans
1. oil the bearings,sae 30 or wd40 for places you cant get into.
dont take fan motor apart unelse you realy have to.
dont let your fan motor bearings get worn egg shaped from lack of oil.
2. make sure fan blades not hitting or scraping fan housing and fan blades are securely fastened to fan motor shaft.
3.mr heater fan motor is 12 volts DC , so it may have a segmated comutator and brushes.
I dont know because i have not yet needed to take my mr heater
fan motor apart but i have worked on hundereds of ac fan motors
in the past 65 years.
4. keep fan motors from getting wet. they hate water.
5. keep fans clean, they dont like foriegn materials.
Your specific problem: first fan 2 weeks,second fan 2 months.
how much you use them, are you wearing the brushes down?
Getting fan motor wet? foreign material getting pulled into fan or fan motor? off/on switch work ok. batterys good,battery contacts ok? fan transformer 110 vac to 12 vdc good? fan bearings oiled?
need more info to diagnose properly.
all of the above needs to be checked out to tell whats happened.
fan & fan motor needs to be inspected.
Feb 21, 2011 | Mr. Heater Big Buddy Heater
CAN YOU USE A BIG BUDDY PROPANE HEATER INSIDE A TRAVEL TRAILER.
Yes you can use it.... BUT!!!!
make sure all combustibles are at least three feet away from the heater....
AND...open a window a bit... 1-2 inches... to allow fresh air in so you do not get CO poisoning...
heatman101
Dec 25, 2010 | Mr. Heater Big Buddy Heater
No propane comes thourgh pilot on mr buddy heater
If the pilot will not light get a q-tip and alcohol and remove the wire grill and be sure the cotton doesn't come off the end of the stick wet the cotton with the alcohol and twist it and push it down into the pilot tube 2 full inches. Let the alcohol soak for 30 seconds and while twisting pull the q-tip out. Try this until the pilot lights.
Jan 01, 2009 | Mr. Heater Mr Heater Portable Buddy...
Mr Heater 1500 propane heater malfunction
How about the thermocouplin have you tested that?
Jan 31, 2018 | Mr. Heater Mr Heater Portable Buddy...
Heating & Cooling Logo
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
