Question about Craftsman Garden
Need to find parts for transmission on 5HP craftsmen tiller. Need input pinion,tine sprocket and gear. Sears tells me these parts are no longer available.Part # are 102113x,106142x and105345x does anyone where i might find replacement parts? Thanks Ron
  • rshorty11 May 19, 2009
    Hi check the sites you suggested but still unable to find anything for positive match on parts i describe on my crafstmen tiller model #917 299710 any other way of getting replacment parts that will show me it is a replacement for the craftsmen part #s i need Thanks.
    Thanks for that site was able to cross reference my part #s but found the same results as i did from sears.com part no longer available. Looks like i am out of luck going to have to junk my tiller.Thanks for trying.
  • 15,935 Answers
Right - since it is no longer supported by the manufacturer - your best bet is to find one on eBay or locally at a flea market or yard sale.
Good Luck!!
Thanks for using FixYa!!
Posted on May 20, 2009
    Sergeant:
  • 296 Answers
Hi
Please find the link bellow which provides links where you can get input pinion.
http://www.freepatentsonline.com/EP1284377.html
for tine sprocket:
http://www.bobvila.com/wwwboard/messages/254139.html
chek this site,u can b helpfull
http://wiki.answers.com/Q/Where_can_you_get_an_owner's_manula_for_a_Craftsman_5.5hp_17_Roto-tiller
Thank You
Posted on May 19, 2009
Need parts for sears 917.299858 shield,tine no longer available at sears
then no longer available... need to rethink your need for this tiller
Sep 08, 2013 | Mtd Bronco Rear Tine Tiller
Trying to find a maintenance manual (exploded view of transmission) for a craftman rear tine tiller (may have been made in Canada), with 5hp Brigs & statton (1985 from motor serial). The tiller serial...
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.Try 917. as the first part of model #.
RGS
Mar 17, 2011 | Craftsman Garden
The tines rotate on my sears rear tine tiller, but the transmission does not engage to make the wheels drive forward or reverse.
Ok, so I Just tore mine down and the input shaft that the pinion gear rides on has wear patterns that cause the gear to not be able to slide and cause it to shift. Problem is probabally caused by poor lubrication as this is at the top of the transmission. I am gonna try to rotate the pinion gear 2 teeth clockwise as it slides smoothly here and add a bottle of lucas automotive oil treatment as it is clingy to gears and more fluid than the grease supplied. My only worry is that it is too thin and may drip from the case so I think I may rtv the gasket. If I really wanted to spend some money on it I would order the shaft and gear from sears at about $70 but I think without better lubrication It would just happen again so I will just try my cheap fix. This is not a hard job but may be too much for some beginers. Hope this info helps.
Jan 14, 2011 | Garden
We have a rototiller, craftsman, bought new at sears several years ago. Model No. 944627591, Craftsman 9 HP, 21 inch tine width, rear tine tiller with counter rotting tines. Pinion input gear is sheared...
The model ID starting in 944 indicates your tiller was manufactured by Husqvarna. This division has since been purchased by AYP. A quick online search finds that www.needlawnmowerparts.com lists having one for $55 plus shipping. I have not dealt with this company, so I can't recommend or not recommend them.
It is very common for tiller makers to not offer internal transmission parts. Transmissions are difficult at best to repair and reassemble. Used tillers are available from time to time, check your local classified ads or www.craigslist.com to find one. If you decide to go with a new tiller, i would recommend trying www.northerntools.com or www.mytsc.com to start your search.
As far as longevity on the new transmission, Sears won't guarantee any of their parts longer than 1 year. However, you should expect a replacement part to last as long as the first one did.
Sears doesn't give year models for their equipment, but usually supports replacement parts for at least 10 years. Most equipment manufacturers don't build their units to last longer than 10 years....they want you to buy another one.
I hopethis has helped.
Jan 04, 2011 | Garden
I need to find out what size belt for tine engagement on a Dayton 5hp Tiller model # 32885 C144B
a simple way to figure out the length is to engage the tine mechanism and take a string and wrap it around the pulleys mark it and take it to any belt store, and buy the Belt you need. You will need to know if it's a 3/8s or 1/2 inch drive belt. Normally tine belts are half inch or 5/8 wide on a 5 horse power motor, You can get these belts at sears or Nappa auto parts store. hope this helps.
Mar 19, 2010 | Garden
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
Breakdown of transmission on craftsmen 5HP rear tine tiller
Little grease on the shaft and some work was able to remove pulley. Found input pinion, tine sprocket and gear all missing some teeth. check with sears and these parts are no longer available. Can anyone tell me where i might find or locate replacement part i need for this tiller?
May 16, 2009 | Craftsman Garden
I have craftsmen 5HP rear tine tiller,while tilling picked up a rock which jammed the tines and stalled the motor. when i restarted it had loud grinding noise and then locked up stopping me from being able...
If the tiller tines where jammed, the tranny and motor where still trying to turn and there could be a couple different parts broken. The tranny main shaft make have busted, the tranny gears could have jammed. If the motor does start, than that is a good sign. If not than the connecting rod or crank may have snapped.
I am guessing you will probably have to dismantle the transmission and see if there are any broken gears or shaft.
May 09, 2009 | Craftsman Garden
Can't find filler plug on transmission
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Apr 24, 2009 | Craftsman Rear Mount Tiller
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Garden Logo
153 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
