Question about Horizon Fitness Horizon T102 12 Program Treadmill
Is it motor or console
Console lights up but the keys don't work and belt doesn't move
2 Suggested Answers
SOURCE: The belt does not move
You have a bad motor control board. It will have to be replaced.
Posted on Jan 23, 2011
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
My pro form treadmill was stuck in the incline position. Now it is down but the belt won't run
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_13_2011_7_47_47_pm.gif11_13_2011_7_48_35_pm.gif
Nov 13, 2011 | Exercise & Fitness
Treadmill only hums when turned on, tread does not work
Hello, it seem there could be something jamming the tread mill belt or the transmission gears coult be broken. There is a very good possiblity that the electric motor has goine south, it doesn't work, or seeze up might have to be replaced.
GB...stewbison
Oct 19, 2011 | Cars & Trucks
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter...
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter don't light up. Help!
Aug 29, 2011 | 1997 Honda Accord
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
NordicTrack T5.3 belt stopped working. It's only 1 month old. Console lights up. Incline works. But belt isn't moving
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Nov 21, 2010 | Nordic Track Exercise & Fitness
I have a Nordic Track Commercial 1500. When I plug in everything comes on find but it will not start. The belt does not move even with no one standing on it.
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Aug 14, 2010 | Nordic Track NordicTrack Commercial 1500...
Belt will not start up and move.
The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity ( capacitors are charged) in the motor area even if the treadmill is unplugged.
If you have a multimeter, you can test to make sure you have DC output from the controller spades ( Drive Motor Connectors) by clipping on them and then pressing the start key you should have a DC voltage reading if not the controller board is defective.
The motor can be tested by using a simple DC cordless drill or lantern battery this will turn the motor if the motor is good the controller board will need replacement , if not their won't be any belt moment the problem is the motor then the motor will need to be replaced. ( if you don' t have a multi meter this method of testing simple and easy)
May 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Horizon Fitness Horizon T102 12 Program Treadmill Logo
13 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
