Question about Kenmore 47834 / 47832 / 47839 Electric Single Oven
Flashed F5 when temp is heating up
Kenmore electric oven flashes F5 when heating up
  • 6,784 Answers
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
Posted on May 21, 2009
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
Oct 25, 2011 | Ovens
Self clean is locked but door still open
oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
Dec 18, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Electric kenmore oven showing an F3 then F5 after it heats up
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$5
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
F5 - Mag Temp
Hi. this is a control fault. the board has lost the ability to communicate its commands to the temp relay. the sensor is also not working. Due to this malfunction, the control board cant regulate the temperature correctly and you will have to replace the board and temp sensor and relay in order to restore this oven to optimal performance.
Please rate and god bless:)
Apr 03, 2009 | TurboChef TORNADO Electric Oven
Kenmore electric range F5 and F3 warnings
May 13, 2008 | Kenmore 30169 Electric Single Oven
Kenmore 47834 / 47832 / 47839 Electric Single Oven Logo
132 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
