Question about McCulloch Garden
McCulloch Chain Saw Jingle - McCulloch Garden
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
  • 4088 Answers
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Posted on Nov 15, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch Pro Mac 610/650 chain
The clutch face may be worn away
Clutch components are on the "General Assembly" illustration; items 8 through 15 here (610 linked - a 650 is 600046):
http://www.ordertree.com/modelinfo/MCC/11-600041-21-PRO-MAC-610-07%2F90-to-Current-IPL-218689-02/139.11-600041-21-PRO-MAC-610-07%2F90-to-Current-IPL-218689-02.1.59.1.html
It appears to be an internal clutch, if true use this as a guide to remove the clutch drum and access the clutch components:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Use this as a guide to remove any necessary remaining clutch parts:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
There may be burrs on the chain drive links (the part that goes in the bar), use a file on the flats to remove any burrs.
The sprocket nose of the bar may be bound up.
I hope you fond this helpful. If I may be of more assistance please post a reply below.
Lou
Posted on Jan 21, 2010
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
What type of gas do i use for my McCulloch 16 Inch Gas Chain Saw
If using an oil other than McCulloch, the ratio is 40:1. Brand Specific McCulloch two cycle oil is 20:1.
Jul 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have an older model Mac 4600 18" chain
Go to Mcculloch.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need owners maual for mcculloch power mac 6 chain saw
Jan 27, 2009 | Garden
McCulloch Pro Mac 610 replacement chain
The McCulloch ProMac 600 series (610/650) doesn't recommend a saw chain replacement part because you can get differently-sized bars for it. This one came with a 20" bar.
According to an Amazon.com search tonight, the Oregon company makes a replacement part stock number D70. I have got an Oregon H78 replacement chain at my hardware store and it's a hair too small. Not all 20" saw chains are created equal!!
Dec 07, 2008 | Oregon Scientific Oregon S54 Replacement...
Garden Logo
46 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
