Question about Roper RAX4233PQ Top Load Washer
My washer spins but will not drain. the pump seems to be working but wont drain
I have a roper rax4232rq4 top load washer and it spins but will not drain.
  • 24 Answers
The drain line is probably clogged... sometimes debris or small objects can get in between the tubs and plug the lines...if not, the pump may be bad. I just replaced my pump on my GE washing machine.
Posted on May 19, 2009
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
Wash machine wont drain or spin
heatman101
Oct 13, 2010 | Roper RAX4233PQ Top Load Washer
Spin cycle wont work
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 23, 2010 | Roper RAS8445KQ Top Load Washer
Washer does not drain and spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Roper RAX4232RQ4 wont spin or drain
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Roper RAS6233KQ Top Load Washer
I have a roper that spins but want drain
Your drain pump is clogged.
Remove the cabinet, remove the pump and remove whatever is clogging the pump.
The pump is located in front of the drive motor.
Mar 03, 2009 | Roper RAK2751WWH Top Load Washer
Roper washing machine
does it spin? drain pump is directly mounted on motor, works in spin. may need new pump. Whirlpool standard pump.
Jun 03, 2008 | Roper RAS8445KQ Top Load Washer
Wont spin
3 things you need to check , 1) check the sensor or latch switch when you close the door , 2) open washer and check the DRAIN MOTOR PUMP it could be clogged with debri in the impellers , and 3) timer switch module replace , hope this helps AJ
May 23, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
181 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
