Televison & Video Logo
A
Anonymous Posted on Dec 29, 2013
Sanyo dp42841 code for direct tv remote - Televison & Video
1 Related Answer
Puppet03
Puppet03
  • 172 Answers
  • Posted on Oct 24, 2009
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
My Sanyo tv dp42841 screen is upside down and mirrored I tried resetting and not fixed how do I get it back to normal with universal remote
You will need to click on the menu button on your TVs remote and then select the factory menu and next click on the factory settings to have the screen be not upside down anymore.
I have a Sanyo Model DP42841 and I want to know how to stop the texting that comes when people are speaking?
If your source is the TV (RF input), then the Caption button on the original remote for the DP42841 will let you cycle through the available closed caption options. If you have a universal remote, you'll need to find a code that lets a Caption (or CC) button work with this TV. This is shown on page 8 of manual. ManualsLib has the manual here: https://www.manualslib.com/manual/148706/Sanyo-Dp42841.html .
If your source is any set-top box, you need to disable the captions on that source. This can depend on the system setup. I know that on one satellite dish receiver, the captions for a second TV on the system had to be enabled from the primary TV. (Then the captions showed on both TVs.) On a IPTV set-top box that I use, to disable the closed captions, I need to enter the Settings menu using a pass code from the provider. Then the setting is under Audio.
I hope this helps.
Sony tv remote codes
Check these codes.
0049 0097 0110 0004 0268 0012 0108 0180
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
