Question about Magellan Battery for RoadMate 2145T-LM, 2136T-LM, 2120T
Reset my magellan 2145 t - Magellan Battery for RoadMate 2145T-LM, 2136T-LM, 2120T
How do I reset my Magellan GPS?
Google Search magellan gps model and reset.
Mar 06, 2015 | Magellan RoadMate GPS
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
Turn on get a screen saying magellan thats it
  • Check if the unit is fully charged. Because if the unit is not charge you will just stay in the magellan logo.
  • If the unit is full charge and still stay in the Magellan logo find the reset button and press and hold the reset button for 15 seconds while its on and then release.
  • If still the same thats the time need to call the technicall support hotline of magellan if they can repair it free of charge.
  • If you need clarification feel free to reply to this solution.
Jun 12, 2010 | Magellan Maestro 4250 GPS
Stereo does not work, dial reads, cod ? Is there a reset code to make the entire system go on?? I just bought this 2001 Nubia and the display lights up but that`s all.....
Try the last 4 digits of the radio's serial number (s/n or s#)
or try the following general codes:
4316 2152 4513 4362
1156 2145 3451 6361
5624 5241 3346 1165
3241 4524 5436 1165 4362 5813 4513 5241 4316 1651 5346 1341 3241 1652 4524 6361 2145 5436 1857 4353 5632 3451 1638 1156 1636 5324
Dec 09, 2009 | 2001 Daewoo Nubira
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
WILL NOT TURN ON
Use a cell phone charger from motorolla razer, it is not wired correctly and the magellen turns on with an error, unplug the magellan from the cell phone charger and it will reboot.
Apr 25, 2009 | Magellan Maestro 4250 GPS
Need raido code for 2001 daewoo leganga please
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451 3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653 5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461
Posts: 4 Radio Code List:
6361,LEGANZA 99
2253, 3116, 3451, 2152, 4362, 4316
4316, 4513, 4362, 1156, 2145, 1156
6451, 6361, 5624, 5241, 3346, 1165
3241, 4524, 5436, 5813, 3265, 5624
2453, 3462, 3251, 5445, 8253, 1156
2346, 4853, 6645, 5253, 1325, 4136
3116, 3221, 2151, 5312, 2654, 4314
6234, 4356, 1415, 1435,1156, 1651
6361
2152 1165 4362 5813 4513 5241 4316 1651 5346 1341
1638 1156 1636 5324
Dec 09, 2008 | 2002 Daewoo Leganza
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Magellan Battery for RoadMate 2145T-LM, 2136T-LM, 2120T Logo
43 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
