Question about Gateway LT2030u Netbook
LT2030U Service manual - Gateway LT2030u Netbook
I dropped my Gateway LT2030u Netbook and now the screen flickers when I move it forward and back. How do I fix this?
I would check for a display connector issue. It may however be a hairline break on the mother board. Have a look.
Oct 31, 2013 | HP Computers & Internet
How do I reset my compaq back to it's original factory settings?
press f10 and altgr at boot screen , repaet as many times as nessary to get it started, this is not an easy task on gateway lt2030u, if your having win 7 problems ,you might want to try pressing f8 at boot up and select the repair optoin it is the first choice in the list.
good luck , tinyman
Jul 19, 2011 | Gateway LT2030u Netbook
How to dissassemble my gateway netbook?
Your Manual Should show you the screws you need to remove. This Does Void your Warranty
May 05, 2011 | Gateway LT2030u Netbook
How do I disassemble a Gateway lt2030u
Hi
If you click on this link it should take you to the website whe can download the manual
you will need adobe reader installed to be able to read it it is a free download
if you save the manual to your desktop or documents you will have it for future use
http://www.retrevo.com/support/Gateway-LT2030u-Laptops-manual/id/23577ci168/t/2/
Jan 26, 2011 | Gateway LT2030u Netbook
How do I remove the bios password?
When requested, type in the password and select the BIOS menu, remove the password option.
Hope that helps.
Jan 15, 2011 | Gateway LT2030u Netbook
When I turn on my netbook, the screen stays black. Nothing appears.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Gateway LT2030u Netbook
Just need instructions on how to replace lcd screen for gateway lt2030u netbook.
If you have to ask "how", I recommend that you STOP, and take the computer to a qualified technician, to have the work done safely & correctly.
Jun 12, 2010 | Gateway LT2030u Netbook
Gateway LT2030u Netbook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
