I have an Akai GX-77 and I determined the capstan motor is faulty - will turn under no load, but has no torque even in Play mode. Can these motors be repaired?
  • cookdr302 May 19, 2009
    I received the response from Wiz and was wondering, if new capstan
    motors are available for the Gx-77, where can they be obtained.
    I think the problem with these motors is the permanent magnet that is
    inside them loses if magnetic field. Otherwise, I can't see
    anything wrong with the motor itself. There is also a control
    board for the motor which the service manual doesn't address. Is
    there a schematic of that PC board available perchance?
    I like this site.
    DCook
  • cookdr302 May 22, 2009
    Wiz's response was very quick and addressed the problem straight on. I am still trying to contact shop.vendio.com. Seems they don;t answer their phone and I've gotten no reply to my emails. Not a Wiz problem though. I am still looking for the GX-77 capstan motor.
    DCook
    Sergeant:
  • 326 Answers
Yes these motors can be repaired.but the repaired motors dont last long as original ones but yes repairs will be much cheaper option then going for new motor. also just incase you require some mini manual for complete description features of gx-77 check the link below: http://audio-database.com/AKAI/player/gx-77-e.html
thanks and please do not forget to accept the solution.thanks for using fixya-keep updated.
Posted on May 19, 2009
  • moniter May 19, 2009
    FG servo direct-current capstan motor x1
    direct-current reel motor x2
    Motors:
    FG Servo D.C. motor for capstan drive x1
    D.C. motor for reel drive x2
    Tape Speed: 19 cm/s ±0.8%; 9.5 cm/s ±1.0%
    and yes you can get the new motor at akain service center online
    this is the direct link for all the required parts available online for akai-gx-77
    http://shop.vendio.com/reelprosound/cate...
    click the link directly
    the cost of motor is $59
    you can order it online.
    thanks.
    please do rate the solution.thank you for using fixya.
My akia gx 625 does not turn at required speed. What needs to be completed to resolve issue
The last time I had one of those and I do not work on them too often on purpose is the capstan shaft was glazed and the Pinch roller was never cleaned. There are ways to deal with the problems but most people are too lazy so they take it to a Technician. The Pinch roller if hard needs to go to Terry for rebuild and the capstan shaft can be reconditioned. The motor needs oiling. Akai used some bad transistors in their units that make noise and have other problems and the glue they used on the PCB sometimes eats the foils away.
Oct 09, 2016 | Audio Players & Recorders
I have Akai gx 230. Its doinf Rew and FF but Play not working, though engages. Tape does not move. Can it be tape threading problem?
Could be either. If you can do some testing, check for power to the capstan motor in play configuration. If there is power at the motor terminals, the motor itself may have failed.
Aug 20, 2016 | Audio Players & Recorders
SERVO CAPSTAN MOTOR FOR REAL TO REAL AKAI GX-77
Check power drive circuit and ohm out traces on control board. The glue they used has been known to conduct and corrode through the foil traces that go to the control circuits.
Apr 17, 2014 | Audio Players & Recorders
I have an AKAI GX-4000D reel to reel machine. It plays small 3" tapes at the right speed, but when I try and play a 7" tape, the sounds are very, very fast and I can't make out what's being...
Yes, that seems to be your problem.
Regardless of the size of reel.
When the:
Capstan sleeve installed is 7 1/2 IPS
Capstan sleeve not installed is 3 3/4 IPS
Hope this helps.
Robert
Oct 06, 2008 | Audio Players & Recorders
Akai gx-646 capstan motor runs way too fast.
You must replace transistor for capstan motor speed ( transistor code is 2SC2336 ). This transistor it is near power transformer.
Jul 23, 2008 | Audio Players & Recorders
AKAI GX-747 does not play or ff or rew. Capstan runs. Stuck in standby forward mode.
My name is Ed, I have the Akai GX-747 Reel to Reel, my problem is when press the play button it engages but the capstan does not spin up to the pinch roller. The reels do not turn.
My e-mail - edward_anderson@comcast.net
Jul 01, 2008 | Audio Players & Recorders
Akai Gx-77 reel to reel tape dech
Good day fixya, thanks to take care of called, the problem I have not solved it then I do not have at the hand a supplier of spare parts, that can offer to a motor for deck gx-77 me of akai Please to provide the contact to me for such aim. If he is not inconvenient favor to then go to the attached mail in Spanish language nonhandling the English language To the attached equal them, the photographic file of the apparatus Thank you very much, RICARDO MARTINEZ CARDONA Cel 3177339950 Manizales Calda Colombia
May 27, 2008 | Audio Players & Recorders
Gx 77 is working now I have solved my prbblem with my friend. where I will get big flat belt for rewinding spool/
Nov 14, 2007 | Audio Players & Recorders
341 people viewed this question
 Grubhead
Grubhead
