Question about Paul Mitchell Flat Iron 1-3/8"
The on/off switch broke off - Paul Mitchell Flat Iron 1-3/8"
Trigger button broke during ironing. What to do?????
The fix is easy, order the trigger that has an actuating tab that is probably broken off. Gently pry up the blue cushion from the front to the back near the cord and you will see the tab lying over the switch. I order my parts from the Rowenta Region Service Center below:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Keep us informed as you resolve and solve the problem. It is a fine machine and well worth the repair.
May 10, 2010 | Rowenta DG-980 Iron
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
Need new water tank for vin067
where can I buy Breville steam iron parts (vin067) as the steam button has broke. Please help!!!
Aug 31, 2009 | Irons
Spring broke on my curling iron
My husband uncurled one wrap on each side of the spring, giving enough wire to stick under the clamp. It's not a good solution, but it works for now.
Aug 31, 2009 | Conair Compact Garment Steamer Iron
Steam trigger broke
i did some research for you and i found out the main web for Rowenta Usa and they do provide spare part as well.
You can also send the iron to a repair center near to you if under the warranty at no cost.
This is the information i got from them
http://www.rowentausa.com/rowenta/frame.aspx
Good Luck
Jun 17, 2008 | Rowenta DG5030 Iron
Rowenta iron
vinegar and water then put the iron on self clean..
then just plain water x2 on self clean.
Mar 21, 2008 | Irons
Paul Mitchell Flat Iron 1-3/8" Logo
Top Paul Mitchell Irons Experts
Are you a Paul Mitchell Iron Expert? Answer questions, earn points and help others
