Question about Sony Audio Players & Recorders
Program my UR5U-8400A controler to Yamaha AV receiver RX-V373.
  • 3 Answers
SOURCE: No Image nec vt465 and yamaha rx v540
You must use the projectors menu to choose the type of input for video out. Your projector is capable of 720p or 1080i high def, but not through s video. If you want high def you must use the component output from your receiver to input on your projector. I hope this helps.
Posted on Jan 26, 2008
SOURCE: yamaha rx-1500 av receiver
some times the speaker cables are touching, double check, I had this with my amp and it kept turning itself off
Posted on Jun 25, 2008
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
  • 3741 Answers
SOURCE: YAMAHA AV receiver RX-V861 I
Check the following:
  1. The first thing to check is to make sure that the sub woofer is connected to the proper connection on the back of the receiver. Please look on the Yamaha receiver and make sure that the sub woofer is connected to the Sub woofer Output jack and not the Sub woofer Multi-Channel Input jack.
  2. Check the LFE/Bass Output setting in the Set Menu of the receiver. Verify it is set to the Both option for best sub woofer performance.
  3. Disconnect the sub woofer cable from the back of the receiver. Once the cable is in your hand verify that the sub woofer is turned on, then tap on the end of the cable and see if you hear anything from the sub woofer. If it is working properly, you should hear a humming or thumping sound from the sub woofer. If you hear this sound then the sub woofer is working and the receivers’ sub woofer output will need to be checked by an authorized Yamaha service center.
  4. If no sound is heard then try replacing the sub woofer cable and repeat the test.
  5. If the sub woofer still does not omit any sound then the sub woofer would need to be tested by a service center.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Posted on Dec 15, 2009
  • 85 Answers
SOURCE: How do I code my Yamaha rx-v361 receiver onto my
To program your remote follow these steps.
1-Turn on the receiver
2-press the "AUX" device key on the remote control
3-Press and hold the "setup" button until the aux key blinks twice, than release the setup button.
4-Enter one of the following codes
30176 or 31176
5-If you entered the code correctly, the AUX key will blink twice and turn off. Now aim the remote at the receiver and press power. If the device turns off, than the code functioned properly. If the receiver does not respond, restart the procedure and enter the other code provided
Good Luck
Posted on Jan 05, 2011
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
Apr 16, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
How to I tell if my receiver is dead?
It sounds like it is dead, check the manual.
Be sure you have mains power to the receiver, it sounds like that failed. A loose plug or blown fuse could cause that type of problem as well. Here are a few links that may help.
Redirect Notice
Redirect Notice
Yamaha RX V373BL Owner Manual
Mar 02, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
No audio from my rx v373
hdmi cable does both vid and sound so you should be ok if you have used this way to connect. if you have used rca connection try using another red white yellow cable cause they are cheap and break easy.
Mar 29, 2014 | Yamaha RX-V373 5.1 Channel AV Receiver
Rx v373 firmware update
Usb crashes after playing several music and stops loading contents from usb. I had to turn the power off and on again to load. Is there any latest firmware for Rx v 373 yet?
Aug 16, 2013 | Yamaha RX-V373 5.1 Channel AV Receiver
Trying to hook up my wii but have sound and no picture I have HDMI cable from tv to yamaha v373 amp and trying to connect the red white and yellow cables to back of amp
Need to put yellow cable into monitor in and choose a input with video vcr, tv, or dvd. still no luck then yellow directly to tv.
Dec 08, 2012 | Yamaha RX-V373 5.1 AV Home Theater...
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Jun 16, 2012 | Yamaha Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
16 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
