Question about Dell Inspiron Computers & Internet
High pitched beep when I try and turn on my laptop
When I turn on the laptop it makes two continuous high pitch beeps and does not turn on. (I just upgrade to 8mg ram)
Benimur
  • 6966 Answers
SOURCE: high pitch noise
For laptop repairs & parts, pls try here. Not really that hard a fix but major concern is how soon do you get the parts and how to confirm your diagnosis.
You may want to consider other possibilities such as:
1. mechanical problem (fan motor bearing, CD/DVD spindle, HD platter; and/or
2. CCFLamp inverter.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 14, 2007
iqbal_del
  • 655 Answers
SOURCE: beep from computer
My lap is also dv6000 and i have no symptoms like that.
it seems some thing is going wrong inside. As your lap is under warranty you should contact your service centre, it will be free.
Thanks
Iqbal
Posted on Apr 06, 2008
  • 3940 Answers
SOURCE: Keyboard letters opkbnm not working on dell inspiron laptop,
Sounds like keyboard failure, replacement keyboards are around $20 on Ebay
Posted on Jun 23, 2009
  • 208 Answers
SOURCE: hi grade laptop makes high pitched noise and the
High pitch noise usually means the inverter board that drives the lamp behind the LCD display. If the rest of the laptop appears to work, for example, hard drive light blinking while booting, try hooking up an external monitor and hit whatever function key that switches you to the external monitor. If everything works, you may want to replace the inverter board yourself. It is not horribly hard if you are very careful. But it is not exactly a walk in the park kind of work.
If the rest of the laptop does not appear to work, the DC-DC step down power circuit is probably shot, which will also make a high pitch noise. In this case, you will have to replace the motherboard. Replacing a motherboard is a major pain in the behind. In most case, it is not worth the trouble if you have an older model.
Posted on Sep 02, 2009
  • 62 Answers
SOURCE: My charger keeps beeping a
i had the same experience like you do, the best solution is buy a new charger before it break your laptop...
my laptop is already broken because i didn't change the charger
please rate
Posted on Feb 28, 2011
Wont start up and high pitch beep
The beeping is from the motherboard most likely. Sounds like you have some kind of virus. You may be able to access safe mode by holding alt+f4 when start-up but other then that I would take your PC in to get checked out.
Mar 20, 2015 | Computers & Internet
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
Computer beeps every 30 seconds
It is car brakes. Turn that game off.
OH, I'M JUST KIDDING!
BIOS speaker is broken, and you hear high pitched beeps?
Hmmmmm,..........
CPU temperature in normal............
What is the CPU, and what is the temp? Hey, I gotta know so we are on the same page here, lol!
Me?
Those repeated high pitch BIOS Beep Codes indicate a CPU problem.
I would remove the Heatsink/Fan combo, and replace the Thermal Paste.
(Following Anti-Static Precautions, and cleaning the CPU, and Heatsink, of course)
Also make sure the Heatsink is sitting flat.
Yes, I know what you stated about Speecy, and Core Temp, but I would try it anyway.
Still no?
CPU is sounding Taps, and telling you goodbye.
Regards,
joecoolvette
Jul 29, 2012 | ASUS Computers & Internet
M2n68-la beep codes
Whenever electronics devices give high pitched beep, it generall means a future failure . There could be reasons for the same.
1. Static built up on the motherboard
2. Conflict on the USB ports.
Troubleshooting 1 :
1. Diconnect all the wires from the tower, including the power cable. Press and hold the power button in the front to remove any static from the motherboard.
2. Check and try again the devices on the USB port.
Troubleshooting 2:
1. Check USB ports for damage , try connect the device to the back of the tower.
Troubleshooting 3
Clear the motherboard setting , use the link attached and see clearing the BIOS settings
Thanks for using fixya
Proton
Jul 07, 2012 | Computers & Internet
On powering up, I get a high pitched continuous beeping and can go no further.
Check ther are no stuck keys on the laptop. Power off, run the palm of your hand over the keyboard and see they all bounce back freely
Jan 01, 2011 | Acer Aspire 5315 Notebook
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Beeps
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 06, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Beep from computer
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire One PC Notebook
Stange beeps
-Reset u r mobile
-Contact motorola care center
Nov 11, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
