Question about Tablets & eReaders
Forgot password on RCA tablet and can't get beyond lock screen
Tablet is locked
  • 24 Answers
SOURCE: COMPAQ TC1000 TABET FORGOT PASSWORD
TC1000 Password Clearing Procedure
1. Discharge any static electricity you may be carrying, it can burn up your mainboard and it doesn't take much! Remove the battery pack and place it out of immediate reach. you will be tempted to snap it back in later before it should be and this will spoil the work. Read everything before you start so you will understand. Remove the mini PCI communications/ memory expansion slot cover (2 small phillips screws, stick them to a piece of tape. When you reinstall them later, start by turning backwards till you hear and feel the threads mesh, then tighten slowly ... you don't want to strip out the threads on your frame! "Lefty loosey, righty tighty")
2. Remove the RTC battery “Real Time Clock (RTC) Battery” This is the black coated nickel sized battery tucked under the frame edge a little. You may have to remove the RAM if you have the extra slot filled to have enough room to work the RTC battery out. to remove the RAM chip pull the spring arms gently away from both sides at once and it will pop up at a 45 degree angle. pull it straight out. to reinstall it later put it back in at an angle, push it gently in then down to let the arms snap onto it and hold it in place. only goes in 1 way, note the notch. Use a toothpick to lift the black plastic film from the edge of the chip as it always tries to get in the way on reinstall. Have some patience or let someone else do it. DO NOT use any metal tools and be sure to remain static free!
Break or cut a short piece off your toothpick to make it easier to use the squared end to push and work the connector of the RTC battery plug off it's attachment. You may be able to unplug the RTC battery without removing it, your call. It connects at the white connector thats located next to the frame rail that separates the battery compartment from the mini PCI communications/ memory expansion bay. It is between (above) the battery release switch and the thumb lift depression to lift out the battery. Now, hold the power switch in the on position for 30 or 40 seconds to discharge any static. This is a good and recommended practice every once in awhile when batt is out and AC is not connected.
moz-screenshot-3.jpg3. Wait approximately five minutes.
4. Replace the RTC battery (or reconnect it)and reassemble the tablet PC except for the main battery, do not install it yet! Remember the toothpick will help you get the plastic film lifted clear of the RAM chip, work it into place at a 45 deg angle and then gently press it down till it locks. DO NOT STRIP out your cover screws, or try to get them super tight. They will strip out your frame, finger snug is enough.
Do not reinsert the battery pack at this time! Thats why you can't reach it!
5. Connect AC power to the tablet PC.
6. Turn on the tablet PC.
All passwords and all CMOS settings have been cleared.
7. Now you can reinstall the main Batt!
Posted on Apr 05, 2008
nashsaint
  • 172 Answers
SOURCE: tablet is frozen will not
Try one of the following:
- Hold the power button for 10 seconds
- Hold the power and up volume for 10 seconds for recovery mode
- Hold the powe and down volume for download mode for 10 seconds
If none of these work then your battery might be completely drained and dead. I suggest you send your contact Samsung Support.
Hope this helps.
Posted on May 07, 2011
michell9016
SOURCE: forgot password on loging on modle #mid8120 tablet
Did You Find Anything On How To Get On ? If So PLEASE Tell Me (:
Posted on Jan 07, 2012
tengzong0214
  • 21 Answers
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
Posted on May 28, 2012
j_lekeydra
SOURCE: forgot password on supernova
how to unlock a pandigital supernova 8 if you forgot your password
Posted on Jun 09, 2012
Forgot home screem password for android ipad
How to bypass Android's lock screen pattern, PIN or password
trendblog.net > Guides
Oct 18, 2015 - How to bypass Android's lock screen pattern, PIN or password ..... Hi can anyone help me I have lost my android tablet device in my bedroom ...
How to unlock an Android phone/tablet - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to unlock an Android phone/tablet
Feb 4, 2013 - But what do you do when you forget your own access code? ... Choose a new screen lock option, such as a pattern or PIN, then enter a code. ... If you've locked your Android smartphone or tablet with a PIN or password, ...
Forgot iPad Screen Lock Password - How to Recover Data ...
www.wondershare.com > Resource > iPhone
Jan 01, 2016 | Tablets & eReaders
Why did I lock myself out of my tablet?
How do I unlock my Tablet when it's locked with a pin code ...
visihow.com/How_i_unlock_my_tablet_when_its_lock_with_pin_code
I locked my tab with a pin lock and I forgot the code. ... Locked out of my Samsung Galaxy S2 i91000? .... can use, the following steps (as well as the video above) in order to help yourself to get back into your device by using a reset combination: .... Cannot get my screen on my tablet to unlock, don't remember pin number?
My Tablet has been locked and I also forgot its Google ID ...
visihow.com/I_have_locked_my_tablet_and_now_I_do_not_know_its_...
The easiest way out right now would be to reset your Tablet. Press the ... Yes ' No ' I need help. See more questions like this: I forgot my pin password on my o+ mobile ...My Android phone has been locked and it asks for Google accounts, but I don't remember which one I used. .... I've tried to break into it myself. How can I ...
Hard reset your Android phone or tablet when you forget the ...
Jan 01, 2016 | Irulu 7" 4gb Mid Google Android 2.3...
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
Locked out ot tablet
HOW CAN I GET PASSWORD FOR A RCA 7" TABLET COMPUTER,IT'S A RCT6077W2 AND S/NAS061CL9B5164 PLEASE AND THANK YOU ON THIS NEW YEAR'S EVE.
Dec 31, 2013 | RCA Tablets & eReaders
I forgot my lock screen password to my xtreme tablet what do i do
If it is running android, you can usually just enter your password 5 times incorrectly and a "Forgot Password?" button should appear. If it's symbian or windows then you probably have to just factory reset the device.
Dec 08, 2013 | Nokia Tablets & eReaders
Forgot lock pattern on lock screen on a 7" uniden tablet
I have a uniden tablet and have had it for about 6 years now I forgot the password and I can't get into it. I have tried everything can someone help? ??????????
Dec 29, 2012 | Uniden Tablets & eReaders
I forgot the password to my samsung galaxt tablet how do I get back on?
I do not remember my pin number at the flashing line so therefore I can't open my Samsung galaxy 2 tablet and I want to have that PIN number totally disabled so this won't happen again.
Nov 09, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
94 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
