Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
Farmall 560 leak from bottom of clutch housing
Small drip from a hole on the right side of the access plate. there is a brass pin/plug in a similar hole directly across the clutch housing. Am i missing a plug of some kind?
  • 6 Answers
SOURCE: The transmission on my 560 Farmall is stuck in
loosen the bolts around the gear shift and put the shifter back into the slot that is not lined up in the center usually it just slipe out and you cant change gears even if it feels like you are.
Posted on Jan 06, 2010
  • 18 Answers
SOURCE: where are hydraulic fluid drain
1 plug under pto 1smaller plug under tractor on front of transmission 1plugunder clutch housing total of3
Posted on Mar 20, 2011
  • 18 Answers
SOURCE: I have a 1959 farmall 560 with a bad PTO. I know
NO it must be tof the same type either band[planetary] or clutch type
SOURCE: dash layout on farmall 560
The operators manual shows a cigarette lighter in that location. It would be just to the right of the starter button. I have an IH 560 diesel, so that's where the glow plug button is located.
Posted on Nov 13, 2012
  • 20 Answers
SOURCE: Farmall 560 hydrolics wont work on the bucket
make sur you dont have lines switched. check fluid levels and lastly check th pump for week lobes
Posted on Jan 18, 2013
Dash layout on farmall 560
Jul 29, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Where are hydraulic fluid drain plugs located on farmall 560
Jan 25, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Is hydraulic fluid really used for both the transmission and hydraulics in the international 460 also where do you fill it?
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Where do you add hydro fluid in a 560 and does it run the power steering also
ther will be acover on rear deck plate next to shifter this is the fill hole check plug will be onleft side of rear end housing under clutch rod [pipe plug] fill until fluid drips out check plug
Jan 09, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Basket is not sitting level inside and a brass pin
the pin was used for shipping it is no longer needed.cannot think what you could of done but possible the triangular skate plate became crooked
Mar 31, 2010 | Washing Machines
Flymo 2200 chain oil leak when machine is running
That chainsaw should leak oil off the bar. A small amount of oil flipping off the chain is how it is suppose to work. If it is a large amount of oil dripping from near the sprocket then you probably need to do some cleaning.
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 01, 2009 | Garden
Transmission stuck in gear
dont know if i answered this one or not you have usually just slipped the gear shifter out of the notches in the transmission ( I heard there is a fixit kit for aprox $400 but never could justify) 1. take off the shift lever (3 bolts). 2. look in the hole and find out which one of the parts are not in line (all notches should be in the center of the hole to be in neutral) put gear selector in wth the tip in the slot or notch that is out of alignment. push down and try to move back to neutral.should move relatively easy.when all are lined up tighten back up (check your transmission fluid hydraulic fluid at this time as it is easiest to add it through the shifter hole. Full plug is located below the clutch pedal and fluid should come out when it is full.
Nov 26, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Almost no free play in the clutch pedal how do i adjust the clutch thx Tim
take inspaction plate off bottom of cluth housing look clutch and though out breaing
Aug 04, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Water on the floor
I've ran into this problem before with another jeep. What happens is the condensation drain line from the evaporator housing gets plugged with the material that insulates the housing and the water can't drain and seeps through the seems and drips on the passenger side floor. Chrysler did at one time sale a plug kit for this. What you would do is drill a 1/4" hole in the side of the housing on the left hand side near the bottom and put a stiff piece of wire in it to unplug the drain line and then plug the hole with the plug kit from chrysler. just when your drilling the hole make sure you don't drill into the evaporator core or your freeon will leak out as well. I'm not exactly sure how far from the bottom to drill the hole if I remember right it is 2 inches just about center. Chrysler did have a service bulletin on this you may want to ask them when you see bout the plug kit.
Jul 27, 2009 | 1998 Jeep Grand Cherokee
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
19 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
