Question about Seiko SUT074 Womens Solar Watch
Resizing watch band - Seiko SUT074 Womens Solar Watch
How to resize watch bands with screws.
Yes you do. There is a screw head at the top and the rest is pin. You need a set of jewelers screwdrivers.
http://www.girr.org/girr/tips/tips6/tool_tips/screwdriver_set_small.jpg
Nov 06, 2017 | Bulova Watches
Tip
How to resize a (Casio) watch band
Because there are a lot of questions about resizing watch bands, I thought I'd add a tip how to do it. Roughly two types of links are used with Casio watches, so I've added two how-to video's:
on Mar 26, 2015 | Casio Watches
Montres Carlo. How can I shorten the band?
WATCH BAND ADJUSTMENT / RESIZE - HOW TO - YouTube
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 | Watches
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
Jul 21, 2014 | Timex Atlantis 100 77517 Wrist Watch
Resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Jan 10, 2010 | Watches
How can I resize a citizen watch with an expandable band? It's a little too big. The owner's manual doesn't tell. Thank you-
If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band.
These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal.
If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
Nov 17, 2009 | Citizen Silhouette Eco Drive Gold Tone...
Resize the watch
If the band is screws then a small screw driver will do the trick. Make sure you use the right size screw driver so you do not strip the screws.
If the band is put together with cotter pins you can push out the cotter pins with a small awl or punch. You want to apply pressure to the end of the pin that is not split or appears to be smooth. Usually when you have cotter pins they are arrows or indicators on the band to tell you which way the pins come out. Make sure you put the pins back the same way they came out.
Sep 17, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Watch band resizing
This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out.
* I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
Jun 27, 2009 | Lucien Piccard 26024 Wrist Watch
Wrist Band Resizing
I did find a solution. I used a push pin tack to push the pins out. Not easy but it did work.
Jun 16, 2007 | Field and Stream F112GUBS Wrist Watch
Seiko SUT074 Womens Solar Watch Logo
26 people viewed this question
Top Seiko Clothing Accessories Experts
Da Doc
ray gallant
Are you a Seiko Clothing Accessory Expert? Answer questions, earn points and help others
